Results 1 to 12 of 12
Thread: Cracked engine mount plate v8
    vs ute
    Mar 2007
    Default Cracked engine mount plate v8
    Today i put my vr v8 up on ramps to see where an oil leak is coming from, while checking around i noticed the 4-5 bolt plate on the block that the engine mounts to is cracked right across and the drivers side was much the same.The rubber engine mounts appears to be in good condition, possibly replaced in the last few years.
    These cracks appear to be from fatigue as the plates have some surface and doesn't look recent. the car has had light front damage from previous owner new bumper and radiator, bonnet etc also car has FE2 suspension (hard ride)
    The radiator support was not changed as they only had to paint one end.
    has any one heard of these plates cracking before (17 year old car) and where would i buy these from genuine??
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    How to change passenger engine mount V8
    Not sure what ur talkin bout, u might be able to pilfer one of these images in link above^^^^^ and draw an arrow at it.
    Reaper
    vs ute
    Mar 2007
    No luck with the link photos, will get under there tomorrow and take photos,i think there called engine mount plates or engine mount brackets.
    Vs Statesman 5.0 - Vn 8plus
    Jan 2011
    hey mate piece of piss - u can get these from holden mate - its a 2 piece engine mount, 1 half attaches to the engine,the other half to the crossmember...ring up preson motors or whoever is ur holden new parts dealer and get them to send u the bracket.. i done both my mounts less then a month ago on a v8 vs took an hour piss all job even have a right up if u want (with bad pictures lol) but u can see how the mount is 2 piece, it bolts together as one or can put each side on seperate. " dont buy makay "!! -http://##############/forum/showthread.php?t=6076
    Jan 2011
    VrWagz1's Avatar
    May 2008
    wollongong
    if its a street commo link then no. Maybe post it up with XXX somwhere in it, and we will have to be creative with our copy/paste funtion
    Reaper
    Jan 2011
    http://stato.xxx.au/forum/showthread.php?t=6076 - Im sure use can work out what the " xxx " is - picutre and small guide for vs v8 engine mount replacement..s
    VrWagz1's Avatar
    May 2008
    wollongong
    unfortunatly you need a login to see the content
    Reaper
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    vs ute
    Mar 2007
    Thanks Great diagram, engine bracket is whats cracked. I hope these are still available from holden?
    VrWagz1's Avatar
    May 2008
    wollongong
    I not for what is worth, rip it out, take it to a boily's shop and have them repair it. Im sure they could also stregnthen it also at the same time so it dosnt happen again.
    Reaper
    vs ute
    Mar 2007
    Will keep that in mind, thanks
  1. Engine mount VR
    By bennyluvsholdens in forum General
    Last Post: 04-07-2009, 04:44 PM
  2. [SA] Anyone need an Engine Mount? VN+
    By travb81 in forum Parts And Other Items For Sale
    Last Post: 01-09-2008, 05:57 PM
  3. engine mount
    By boots_lacey in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2008, 08:57 PM
  4. engine mount
    By exa89 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-01-2008, 08:12 PM
  5. Engine mount
    By satos in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 27-12-2007, 07:18 PM
