Results 1 to 9 of 9
Thread: Spark plug leads
    VX SS
    Jun 2005
    Default Spark plug leads
    Hi everyone,
    Well the ute is misfiring underload, so Im going to change the spark plugs and leads in it.
    One of the leads got damaged as I was pulling by the cord instead of the head of the lead (whoops).
    Question is, are genuine leads better or just use some Bosch or Top Gun ones?
    Thanks
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I just used Bosch as they were the cheapest and they are pretty good quality. It's debatable whether expensive ones work any better.
    vs commodore
    Oct 2009
    Tamworth NSW
    The main thing is replacing them regularly as the voltages they carry these days is very high with EFI,so they dont last very long anyway compared to how long they'd last years ago with the old points systems..a set of leads would last for years back then..I replace mine on my VS every 12 months.
    Sep 2007
    I think I paid $60 for a set of eagle 8mm. They are probably the most highly recommended aftermarket ones. Its just the insulation thats a bit thicker, not the actual core itself. If your leads are rooted any new set will do the job though.
    joshyewahh's Avatar
    joshyewahh is offline ding ding dinggg!!!
    2005 VZ SV6 Alloytec190 6spM
    Jan 2011
    Sydney NSW
    i swapped my stock leads n spark plugs for Top Gun leads and NGK spark plugs, n saw a great difference
    VZ SV6 now, Jelly?
    som
    som is offline
    vt executive
    Apr 2011
    thorneside qld
    i believe that genuine leads are heaps better than top gun but i guess it's like everything else, there are lots of different opinions.all i know for sure is that i tried top gun leads a couple of years ago and they were breaking down after 50,000km.i usually change my genuine leads every 80,000km which is before i notice them breaking down.as far as plugs go.genuine or ngk,i can't complain about either. don't overlook the possibility that your coil pack could also need replacing.good luck.
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    VX SS
    Jun 2005
    Will check out some prices for leads at Repco and Supercheap tomorrow.
    There is a full service kit and all on Ebay with genuine leads for a pretty good price, although I'd like the car running again this weekend.
    How do you know or how can I test the coilpack?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check the primary resistance 0.3 - 1.5 and secondary resistance 5 - 7 kohms.
  1. spark Plug leads
    By paulbenning in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-07-2010, 09:04 PM
  2. spark plug leads
    By AndyVKSSA in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 11:26 AM
  3. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
  4. Spark Plug Leads
    By Ratty in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-07-2005, 01:49 AM
  5. spark plug leads
    By pcp20us in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-10-2004, 01:30 AM
