Results 1 to 6 of 6
Thread: vr rear clicking noise when turning??
    vrII wagon
    Dec 2008
    vic
    Default vr rear clicking noise when turning??
    i have a vrII wagon and when i turn right and somtimes left i can hear a clicking noise coming from the rear left wheel... what is it?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check the wheel nuts are tight, also get under and check the suspension components - there are quite a few that will cause a noise when turning.
    vrII wagon
    Dec 2008
    vic
    vrII wagon
    Dec 2008
    vic
    okay, now that its been a while i can see that my new rims are rubbing on the inside of my arches,
    when i push againsed the side of my car it moves to the side a fair bit how do i fix this?
    ive replaced the shock and swaybar links bushes but thats all as i have no idea what i should replace to stop it moving side to side
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If you have the solid rear end - not independant, then the problem will be worn panhard rod bushes - cost about $40 for the pair and very easy to instal. The panhard rod locates the back axle/diff from moving sideways. These bushes have a habit of failing.
    See: Panhard rod - Wikipedia, the free encyclopedia
    vrII wagon
    Dec 2008
    vic
    thanks man
    willl look into it
  1. VX calais 5.7 , clicking noise from left rear wheel area, any ideas ?
    By comfortss in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-08-2011, 09:55 PM
  2. Rear wheel hub replacment, or bearings, loud hum noise when turning at 50+ km/ph
    By welchy92 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-03-2010, 06:25 PM
  3. clicking noise in the rear end
    By ratz26 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-10-2009, 09:21 PM
  4. Clicking noise from rear of car VX SS
    By Kevin101 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-09-2009, 09:34 PM
Tags for this Thread
