Results 1 to 3 of 3
Thread: grinding problem
    sprayzz's Avatar
    sprayzz is offline sprayzz
    vs commodore
    Dec 2007
    Default grinding problem
    hey guys would anyone tell me what this could be.. when i drive on the highway and im going around a left bend i get a constint grind.. but once i go right around a bend its gone , its only when i go left. i dont feel a grind if im cruising around town only when 80km + .... also when i turn left ina street or driveway i hear a clonking sound... same thing only when going left. so if anyone could shed some light it would be great
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Could be the driver side front wheel bearing gone, or the engine mounts gone allowing the engine to move sideways. Best way to find out is rock the car side to side and see if anything clunks, jack eack wheel up and check for play...etc. But really it could be one of a hundred things. Check your brake pads too.
    sprayzz's Avatar
    vs commodore
    Dec 2007
    thanks mate will def give it a try
  1. LS1 Grinding into 6th
    By johnno010684 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-01-2011, 10:10 PM
  2. Weird problem with VN - Grinding / Freespinning noise
    By Defected in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-05-2010, 06:13 PM
  3. Help! Grinding into 4th gear
    By Pat0 in forum V6 Development And Modification
    Last Post: 23-04-2010, 11:22 PM
  4. grinding problem rear end
    By tiersum in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-02-2010, 10:42 PM
  5. Grinding!!!
    By AttaBoy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2005, 02:48 PM
