Results 1 to 4 of 4
Thread: wagon legal springs
    vrII wagon
    Dec 2008
    vic
    Default wagon legal springs
    okay i have a vr wagon sits like a tractor
    has anyone lowered one before?. im thinking super lows all round but the law in vic is 100mm off the ground and id like to stay legal
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    I think every second person here has lowered their cars to some degree. I run super lows in the rear of mine. Personally its too low for me as i do a bit of towing ect.. and i found the king springs to be very soft, bit like stock springs, and nothing like the pedders HD i had in previous which were rock hard.
    But the main reason i did it was i went for a smaller rolling diameter wheel (vx ss 17's with 45 profiles) and the rear arch was way to high, so it looks better and rides better, but dosnt suit when im towing. Fronts are all pedders ect..
    Anyway enough Blahblah, All im sayin is make sure the springs you get suit what you do. I would of preffered stiffer super low rear springs but now im stuck with these soggy things ftm as im not buyin more. But my front setup is unreal, stiff springs, slightly lowered, good shockies, hard rubber strut tops, heavy duty sway bar, makes for a solid front end which handles nicely.
    Reaper
    GEN3RATD's Avatar
    GEN3RATD is offline living the low life
    VXII SS
    Nov 2010
    Crib Point, VIC
    SL's will put you under legal i reckon. either A. risk it like everyone else on here does or B. go lows.
    If it isnt tuckin, it must be suckin
    VS Stato l67
    Mar 2009
    Melb
    Just risk it with some SL's. It might come in just under legal like mine does, but it doesnt look stupidly low, and its still practical.
  1. lowest legal springs.
    By dumpedvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-08-2010, 11:00 PM
  2. Replies: 47
    Last Post: 15-06-2010, 10:19 AM
  3. 19 inch rims with ssl king springs legal?
    By vrcommodude in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-05-2009, 03:40 PM
  4. swap vl springs for vr wagon springs
    By Sabby in forum Swap / Wanted to Buy / Trade
    Last Post: 04-10-2008, 04:42 PM
  5. legal springs
    By dobbie in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-03-2006, 10:50 PM
Tags for this Thread
