Results 1 to 6 of 6
Thread: VS Executive wagon not starting and only code is 92
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Default VS Executive wagon not starting and only code is 92
    A mate has just brought a VS Executive wagon was going fine for a couple of days then just stopped (cranks and gets a fire every once in a while but won't start), so I ran a code check and came back with Code 92 - Low Speed Radiator fan response signal but it would seem that the code is from a mod to the thermo fans and I don't think it is the cause so here is a list of parts that have been replaced
    - Battery
    - Coil packs
    - DFI
    - CAS
    - Engine computer
    - Balancer
    - Air flow sensor
    - Temp sensor
    - Fuel pump
    - Fuel filter
    as it sits the fuel pump works when key is turned on all the fuses are fine but it does this strange thing that I've never seen on a Executive and that's when you turn the ignition on the indicators flash until you press the unlock button on the key but as far as I know the car should start as it has the sensor on the key, and has a weak injector signal pulse but has good spark?
    The only thing that looks weird is some on has used the power window fuse and regulator and marked it hot wire (WTF?) but none of this had been touched.
    Any ideas sorry for long post but it's been going on for a couple of days know and starting to wear thin?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Sounds like your car may have some sort of aftermarket immobiliser fitted or partially removed. That will need a lot of searching/testing of wires to find. May also be a bad Key reader ring - the shiny ring thing where the ignition key fits in the keyhole...it makes contact with the tit on the keyhead to tell the BCM that it's OK to start the car...if bad it will prevent the car starting by killing the injector pulse from memory.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Quote Originally Posted by hako View Post
    Maybe but i hope not!
    Already tried that as well.
    Cheers Pat
    vs commodore
    Oct 2009
    Tamworth NSW
    A bad/faulty ignition key fob or key reader will stop the car from even attempting to wind over,just like when you try to start an automatic car in gear..
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    DTC 92 V6 PCM
    LOW SPEED FAN NO BCM RESPONSE
    The PCM determines operation of the two speed engine cooling fan based on A/C request signal input, engine coolant temperature, and vehicle speed.
    The engine cooling fan low speed relay (labelled LO FAN in relay housing) is energised by the BCM. When the PCM determines that the engine cooling fan low speed relay should be turned ON, the PCM will send a message on circuit 1221 to the BCM. This message will ask the BCM to earth circuit 473 and energise the engine cooling fan low speed relay. After the BCM provides the earth for circuit 473, the BCM will send a message back to the PCM saying that the earth circuit was commanded. The DTC 92 will set if the PCM sends out the message to the BCM to turn ON the engine cooling fan low speed relay and the BCM does NOT send a message back to the PCM.
    An open or short to earth on circuit 1221 will disable any communication of serial data between the PCM and BCM.
    Diagnostic Aids:
    Dirty, Damaged, or Loose Connections or Damaged Harness - Check for any damage to the harness which could cause an intermittent open or short to earth or backed out terminals at the BCM module connectors, broken locks, improperly formed or damaged terminals.
    The engine will not start if circuit 1221 is open or earthed. Therefore if DTC 92 is set and the engine will start, DTC 92 is intermittent. Review DTC history data to determine when DTC 92 set.
    Circuit Description:
    VS Executive wagon not starting and only code is 92-dtc-92-wiring-diagram.jpg
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Interesting so maybe I'll have to have a look at the dodgy fan wiring tomorrow!
  1. Code 31 & troubles starting.
    By Kurtp in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-01-2010, 09:14 PM
  2. VT Executive Series 2 Starting problem
    By GIARU5 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-12-2009, 09:31 PM
  3. vr vs starting problem code 31
    By Peter4690 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-01-2008, 11:55 PM
  4. code 24?? help!!-----vr executive, 1994
    By protossw in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 10:38 AM
  5. Pin code for VY Series 1 Executive CD player
    By mvrettas in forum Car Audio
    Last Post: 03-11-2006, 08:28 AM
