Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By 304runner
Thread: testing coil packs
    wb panelvan
    Sep 2010
    nambucca heads
    Default testing coil packs
    hi guys,
    did a search on here but could find no exact explaination on how to do it. how do u test the coil packs on a vs engine to see if they r not work correctly? how do u do it with a multimeter and without one?
    cheers
    vs commodore
    Oct 2009
    Tamworth NSW
    To test these coils with a multimeter,you just measure the resistance of the primary and secondary coil windings.
    The primary resistance should be between 0.3 -1.5 ohms. The secondary resistance should be between 5 -7 kohms.
    The primary resistance is measured from the two contacts where the coil contacts the DFI module.
    The secondary resistance is measured from the two spark plug lead connectors on the coil...
    Ive seen these coils show up to be ok when tested on a multimeter,but it was still causing a misfire,so you cant fully rely on the multimeter readings.I keep a new coil that I use for testing,I just swap it with each of the 3 coils and drive it each time to see how it runs,If one of the coils is not 100%,then you will notice it as soon as its replaced with a new one.Ive found its always best to replace all 3 coils at once and to only use genuine holden coils,or good aftermarket brands like MSD
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    An ohm meter works fine for testing cct resistance, but it will never test the insulation resitance properly @ 3V or whatever ur ohm meter might be. An insulation resistance tester(megger) is the only way to check them properly, even then it will not fully test the secondary fully unless you happen to have a 10kV+ megger.
    Reaper
    VR Executive 3.8
    May 2011
    wb panelvan
    Sep 2010
    nambucca heads
    thanks guys, ill have a go a see what i can come up with. cause its a got a pretty bad misfire atm.
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Not my domain at all.. It was easier for me to learn German then instal my CD player!
    "Brett_jjj" should be going head to head with Julia by the sounds of it
  1. Testing coil packs.
    By soop in forum LSx Development and Modification
    Last Post: 05-12-2011, 09:26 PM
  2. Coil Packs
    By Ezybrezy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-09-2010, 12:28 AM
  3. Coil packs
    By AdamAnt in forum Electrical Wiring / Questions
    Last Post: 08-08-2010, 10:02 PM
  4. msd coil packs
    By bigneilsen in forum V6 Development And Modification
    Last Post: 25-11-2009, 08:10 PM
  5. Coil Packs
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2008, 05:31 PM
