Results 1 to 21 of 21
Like Tree1Likes
  • 1 Post By spud_22
Thread: Transmission fluid change
    spud_22's Avatar
    spud_22 is offline Ruled by the P
    95 VS Berlina
    Nov 2010
    Default Transmission fluid change
    Hey guys I’m going to be doing a transmission fluid change. Just want to know if the is any way to drain the fluid out of the torque converter and the body of the transmission. Last time I did it the fluid was still s**ty looking after I filled her back up.
    vs commodore
    Oct 2009
    Tamworth NSW
    You can undo one of the trans cooler lines near the radiator and start the engine to pump out as much trans fluid as it can,then drop the trans pan as usual once the fluid stops pumping out of the cooler pipe,and dont run the car for too long once the fluid has stopped coming out of the cooler pipe..This should get most of the fluid out of the system,and keep in mind that the dry refill amount is just under 9 litres of dexron 111(3) trans fluid.Whereas when you just drop the trans pan to change the filter,the refill amount is only around 5 litres.Usually just under 5 litres.
    spud_22's Avatar
    95 VS Berlina
    Nov 2010
    vs commodore
    Oct 2009
    Tamworth NSW
    VR Executive 3.8
    May 2011
    thanx spud for making this thread as i was due to ask the same question, and thanx brett for the advice on this
    vr v6
    Aug 2009
    Maybe you can change your engine oil by removing the oil sender and starting the engine to drain the oil it at the same time.
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by Guzzoline addict View Post
    What a stupid suggestion.. Just goes to show that some people should not even be allowed near a car.
    spud_22's Avatar
    95 VS Berlina
    Nov 2010
    OK guy i will be doing this on sunday so ill let you know how it all goes
    3.08 LSD, 1.9.1 High Ratio Rockers, MACE CAI, Spacers
    VS Berlina Sedan.
    Jan 2006
    New Zealand.
    Forget changing your Engine oil this way if you don't know how get someone who does.
    White E3 Clubsport
    Oct 2010
    Quote Originally Posted by Tomboy View Post
    Constructive..... Some of us are only learning how to work on our cars properly (I'm 36 and only now getting people to show me the right way to do things).
    Maybe a 'how to' might have been a better answer. Sorry mate I just think we should be helping one another
    Bonners White E3 Clubsport - SV Enhanced
    Wortec Brakes Distributor
    spud_22's Avatar
    95 VS Berlina
    Nov 2010
    Its not that hard to do. I was just unsure of how to do a full drain. Doing thing by your self is fun and you end up saving heaps of money for not paying labour cost. I might take some pictures as i go and write up a how to for people. Yay or nay for a write up, what do you guys recon.
    1997 VS Berlina
    Apr 2011
    South Sydney
    Quote Originally Posted by spud_22 View Post
    yay it would be a great help seeing as im gonna do this soon
    spud_22's Avatar
    95 VS Berlina
    Nov 2010
    OK cool ill take heaps of pics and try get it up on sunday night, monday at the latest
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    i do my full trans flush like that all the time, i drop a bit out via the cooler hose to make removing the pan easier, though i never let it run dry which is bad, i then drop the pan, change the oil and filter then fill it backup, then pull the cooler line and start er up, keep slowly filling the pan with oil while the pump will push the old oil out via the cooler hose, as soon as the fresh fluid comes through it's flushed out, put your cooler hose back on then, run it upto temp and get your level right on the hot marker.
  15. #15
    spud_22's Avatar
    95 VS Berlina
    Nov 2010
    Mate i wanted to do a flush but i just cant afford to buy all the fluid ATM. I have heard you need allot. How many litters do you use?
  16. #16
    The1's Avatar
    Jan 2005
    Toowoomba QLD
  17. #17
    spud_22's Avatar
    95 VS Berlina
    Nov 2010
    That sucks. I can only afford 2x 4L bottles and the filter. Owell ill make do with the way the guys have told me at the top. I will just make sure i dont run the transmission dry
  18. #18
    VR Executive 3.8
    May 2011
    if you can spud try and hold of until you can get that extra bottle, thanx everyone for the input as now spud can fix the tranny and i am grateful for this thread
  19. #19
    spud_22's Avatar
    95 VS Berlina
    Nov 2010
    I would love to hold off but my trans fluid is black ATM and its not running so well. Thanks everyone for the input it is much appreciated.
  20. #20
    VT V8 Calais
    Mar 2007
    Let us know how it goes, would be great to see some pics taken too, will need to do this to the Calais too.
    50LTRv8
  21. #21
    vr v6
    Aug 2009
    Quote Originally Posted by Brett_jjj View Post
    I was being sarcastic,my point being you wouldnt do it to your engine so why would you be stupied enough to do it to your gearbox.
  1. Transmission fluid change?
    By VT97 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-04-2012, 12:31 PM
  2. [VY] How to change transmission filter and fluid.
    By VYMAD in forum Holden Commodore How-To's
    Last Post: 22-09-2011, 05:21 PM
  3. how to top up transmission fluid
    By nielsonp in forum General
    Last Post: 03-02-2010, 09:13 PM
  4. Transmission Fluid
    By Deutscher in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-09-2009, 03:04 PM
  5. Transmission Fluid
    By MavVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-08-2004, 10:07 PM
