Results 1 to 3 of 3
Thread: radio security code
    VS Executive
    Jun 2011
    Gold Coast
    Smile radio security code
    Just bought a VS but no owners manual, have the radio code but need procedure to make it work, e.g. what buttons do I hit and in what order. Cheers
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    From a vt should work.
    Taken from the radio handbook from a VT
    1. Turn ignition to accessories position
    2. "1" will appear on the display
    3. Use the 6 preset buttons to enter the supplied 4 digit pin number. As each number is entered, the number is shown on the display
    4. If the correct pin was entered, the radio will become operational. The release procedure will NOT have to be performed again, unless the cars battery is disconnected
    5. If the incorrect PIN was entered "2" will appear on the display
    6. Enter the correct pin and the radio will operate. Should an incorrect pin number have been entered agai, "3" will appearin the display. The radio will only accept the pin number once more. Should this attempt be incorrect again the display will show "---" and the radio must remail in the car for approximately 1 hr before the correct pin number can be entered. The key can be removed from the ignition during the hour, but remember to turn it to accessories when attempting to re-enter the pin. If "---" still appears on the display you may need to wait a little longer.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    vs berlina
    Sep 2010
    south coast n.s.w
    or if you are planning on getting a new headunit you wont need code
  1. can some 1 help me i need a radio security code 4 my vs
    By jes51 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-02-2011, 09:43 PM
  2. radio security code
    By Duck_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-07-2009, 10:13 PM
  3. Radio security code
    By jyothi in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-06-2008, 02:32 AM
  4. security code for eurovox 6616 car radio
    By peter0470 in forum Electrical Wiring / Questions
    Last Post: 28-10-2007, 09:33 PM
  5. Security Code On Radio
    By troy5.7 in forum Car Audio
    Last Post: 13-02-2004, 02:42 PM
