Results 1 to 11 of 11
Thread: vs motor wont work
    holden vs
    Mar 2010
    Default vs motor wont work
    hey iv just pop a vs ecotec and 5 speed into my vk wagon iv brought a Memcal with the vats trun off etc now iv got spark and fuel but wont start. thinking injeters? or is there something i could be missing in my wireing for them not to be working?
    Built with Spanners. Not chops sticks
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'm only guessing, but normally you need the key/keyhead to communicate with the BCM which then disengages the immobiliser....but you don't say if you've used the whole harness and if you have used the BCM...but like I said, I'm only guessing. Maybe check out one of those places that instals Ecotecs to Toyota Hiluxes...they will know.
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    So with the vats removed I assume you're using no BCM? Yes I agree if you have spark and fuel supply i'd be checking for injector pulse next. The pulse however is too quick to be measured with a multimeter or test light to see if its working. You need to do this with a 'noid lite' which is similar to a small light globe you plug into the injector plug in the harness and with the motor cranking should see a flashing of the light with each pulse for that cylinder.
    All your earths are good? Both engine to body and pcm to body?
    Have you given the PCM both a constant and ignition power source where required?
    I assume you're cranking off the vk ignition key and just shorting across the starter motor?
    holden vs
    Mar 2010
    hi no im not useing a bcm that why i got vats trun off so i didnt have to mack around with all that stuff as well. yea iv got a constant and ignition power ( iv got one constant and 1 ignition wire ) is that all there is? and i have it truning off the vk key going though the vs starter relay then to starter motor ill do i bit of a check on my earths 2moro but they should be all there thanks for your help ill try and check the injecter pulse but i would say if it was working the car would start. i dont have the gearbox in would that do anything? every thing is manual (wiring etc)and from a manual car
    vs commodore
    Oct 2009
    Tamworth NSW
    What fuel pump are you using?If it doesnt get enough fuel pressure up,the injectors wont fire properly..
    holden vs
    Mar 2010
    iv got a vn-vs fuel tank with vn-vs fuel pump in it. fuel comes out the fuel rail back into the return line back to the tank so its got engough pressure cheers
    Aug 2008
    NSW South Coast
    Having no gearbox in it at the moment won't stop it from running. Fuel pump should also be run through a relay, powered via the pcm, not hard wired to accessories or ignition. Once again though this wouldn't stop it running, just kill pumps in no time.
    From memory you'll need 1 constant and 2 ignition power sources to the pcm, but i dont have a diagram at the moment sorry. Should also be at least 3 wires at the pcm which need to be earthed.
    If all looks good i'd be investigating frther for injector pulse as i mentioned before.
    holden vs
    Mar 2010
    well i checked the wires at the pcm theres 2 constant about 7 ingition+ wires and a hand full of earths
    holden vs
    Mar 2010
    also the car i remover motor from was mint runner
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    there should be 2 constant powers and 2 pink wires that are switched ignition power
    holden vs
    Mar 2010
    hey cheers got her going this moring nice and loud haha now i can put gear box in. i found a wiring diagram of the pcm which help me here the link if it helps anyone
    http://www.boyod.net/download/Holden...ng-Diagram.pdf
  1. fan wont work
    By michaeldavies in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-06-2010, 08:29 PM
  2. JC wont work!!!!
    By Troyziee in forum Site Feedback / Site Problems
    Last Post: 07-09-2007, 05:12 PM
  3. Speakers wont work??? Help please!
    By auc05l in forum Car Audio
    Last Post: 21-10-2006, 09:55 PM
  4. Vp Air Con/heater Wont Work
    By robbie11 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-06-2006, 06:02 PM
  5. sub wont work
    By vpwgn in forum Car Audio
    Last Post: 11-04-2005, 09:10 PM
