Results 1 to 7 of 7
Thread: Hall Rotor Removal V8
    vs ute
    Mar 2007
    Default Hall Rotor Removal V8
    I am replacing the hall sensor in my distributor, i have removed the circlip that holds the hall rotor on the shaft now having trouble removing the rotor.
    have tried using two screw drivers but i dont want to force it or damage it.
    Have sprayed a small amount of wd40 on shaft, slighlty rusted is there any tricks to remove this without damaging it?
    vs ute
    Mar 2007
    Had to remove the distributor and completely and dissemble it, still cant get the hall rotor of the shaft. Looks like a press fit that has welded itself on there.
    One thing that i leaned is not to even slightly try to pry this off as they bend quiet easily, as mine was and was catching the hall sensor as i rotated it to disassemble it. Looks like am now up for a new distributer or parts from another i can use. the hall rotor will no longer be able to be used as i have damaged it trying to get it off the shaft. Does anyone know if those cheap $65 distributors on e/bay would be any good?
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    I had Dizzy Issues with my car... I also damaged the hall effect sensor with I was removing mine.. Just dont do what I did and put it back in wrong. I was 180 out, then I was tooth out ect...
    Vs Statesman 5.0 - Vn 8plus
    Jan 2011
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Check out the instructions and diagram below:
    Attached Thumbnails Attached Thumbnails Hall Rotor Removal V8-v8-distributor.jpg
  1. vp hall effect sensor
    By adamandtanya in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-03-2010, 09:00 PM
  2. VR-VS brake disc rotor removal
    By roon_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-09-2009, 08:36 PM
  3. hall effect sensor
    By MiSs MeOw in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-05-2008, 05:35 PM
  4. VR 5L Dizzy Rotor Removal
    By mess666 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-12-2006, 11:31 AM
  5. VS non ABS Front Brake rotor removal
    By Patrio7 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-07-2006, 01:33 PM
