Results 1 to 18 of 18
Like Tree1Likes
  • 1 Post By Cracka
Thread: VS Climate Control Problems
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Default VS Climate Control Problems
    Hey all,
    I have a 1996 vs berlina, An no matter what setting you put it to on the climate control as in air vent direction.
    It stays on feet...
    Any help?!?
    Mat
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    VP Exec
    Jun 2005
    Just like the manual set up, the CC default without vacuum is to the feet, so... looking for a vacuum leak in the system somewhere would be a good place to start. Maybe try the usual suspects: vacuum ball under the guard, the one way check valve under the bonnet, the hose connection - black hose is the vacuum source - to the back of the CC bank of solenoids.
    shanhsv's Avatar
    shanhsv is offline Luvo
    VS Berlina V8 5speed
    May 2005
    Muswellbrook,NSW
    mine is doing basicly the same thing except my demister is the only other setting i can use without it going to the feet. There should be a sensor under the radio,its just a 4in or so long box with 5 holes in it,this sensor is often the reason.
    WTB:VR/S HSV 250km/h speedo cluster
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    I second the Vac leak ^^ as above on this issue - default is warm air to the feet.
    and 3 Dangerous non ABS VN's
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Thanks guys!
    Suggestions or photos where to look, as I only picked this up on Wednesday an I dont have a gregory's just yet.
    Mat
    Cracka is offline Banned :P
    Old Sneakers
    Mar 2011
    Croydon
    IF your vent stays on feet unless you throttle it or it decides it will change direction at random then the below is for you, and well anyone.
    below your CD player (If you have digital climate control) is an electronic vacume solenoid cluster, its a slim black box with wires and vacume hoses going to it.
    Unplug everything, unnscrew it and remove it, it pulls appart very easily and is a simply device, clean everything, replace the filter in it with some foam and cotton cloth, reinstall.
    When I did this I stripped every component down, cleaned them all and blew it out with compressed air. You can buy the part brand new from Holden but its like $120 for something that can be serviced for free.
    That in my experience is the most common cause.
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Quote Originally Posted by Cracka View Post
    I will try that tomorrow! Cheers for the info.
    Mat
    P.S- With car idling & the climate unit turned off, I can hear a "hiss" behind the radio somewhere as well.
    Old Sneakers
    Mar 2011
    Croydon
    maybe a cat is stuck behind the radio
    Nah that could be a vac leak at the unit or if one of the solenoids is jambed or stuck slightly open it will leak too. I'll be interested to see how it goes, it can be a bugger to get to the unit sometimes, last time I ended up taking half the interior out, luckily the dash can stay in.
    Quote Originally Posted by Julie View Post
    Just curious why a fella without kids wants to know what our kids eat... are you that dude in the dodgy free candy van?
    http://forums.justcommodores.com.au/signaturepics/sigpic83720_1.gif
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    I'll be sure to take photos
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by HoZy View Post
    Mat
    Sounds like the tube has poped on the unit. But you have to take the console apart to get to it
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Hey all,
    Struggling to get the vac lines plugged back into the solenoid box.
    Suggestions?
    Sent from my iPhone using Tapatalk
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    I go it!!
    It works, ####yeah.
    One more thing to tick off my list of stuff to fix :-)
    I cleaned the filter an also put some
    O-ring lube on the vacuum holes or a better seal.
    Now I have demister :-)
    cheers
    Mat
    88GreenVN's Avatar
    Jun 2006
    Did you put a cable tie back on the vac connection to the solinoid pack? (if you took it off)
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Quote Originally Posted by 88GreenVN View Post
    Didn't think of that....
  15. #15
    Old Sneakers
    Mar 2011
    Croydon
    HAHA! glad it worked mate.
  16. #16
    VS Berlina/ KJ Verada
    Sep 2006
    replace the filter in it with some foam and cotton cloth.
    how exactly did u do this part mate? tried to clean the original filter but it fell apart in my hands!
  17. #17
    Old Sneakers
    Mar 2011
    Croydon
    I said replace the filter, not clean it. I got some 3mm thick foam (An offcut from clark rubber) and cut a square of cotton off of an old pillow case, wrap the foam in the cotton so little pieces dont break away and enter the solenoid assembly over time, this is why they block up and dont function.
  18. #18
    Sep 2006
    Cool man, i did it a while ago, before i read that! basically having the same conversation in 2 threads, haha! Thanks for ur tips mate.
  1. vs climate control problems
    By lawnwarrior in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-05-2011, 09:23 AM
  2. vt climate control problems, please help
    By slepar in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-06-2010, 07:42 PM
  3. Climate Control Problems
    By dashortman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-12-2006, 11:21 AM
  4. VS Climate Control Problems
    By robert_buntine in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2006, 03:28 PM
  5. Climate Control Problems
    By sixshooter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-01-2006, 12:00 PM
