was driving my vs berlina last night and the left indicator came on and stayed on (didnt flash) and wont go out, i can still indicate right but while doing that the left one is still on, only seems to do it when lights are on works fine when there off, any ideas on what would cause that?
blown fuse/globe/tailight short. check ALL fuses, and have someone check your light front and back from all combos to see if theres a short.
ok will try that tomorrow morning thanks heaps man
check the wiring to your front and rear left hand side lights for any damage, also check the wiring for your trailer plug if you have one (you may need to pull it apart)
i highly doubt any blown fuse would cause these problems
