Results 1 to 8 of 8
Thread: airbag light on and tech1/2 wouldnt fix problem
    96 vs calais series 1
    Apr 2011
    maroochydore
    Default airbag light on and tech1/2 wouldnt fix problem
    hi guys, took my vs calais to auto elect yesterday to clear a fault light, i had replaced the passenger airbag cushion and remover centre consol ect to work on the radio etc. after all was done this light came on. the auto elect said his diagnostic machine wouldnt register there being any airbag circuit, said could be a blown fuse or faulty module. any thoughts??
    Apr 2011
    maroochydore
    dont even worry guys! i just checked the fuse and it was blown, some tech he was!!! i just assumed it wasn't a fuse blown, that would be too easy. MUST NOT ASSUME!! calais all ship shape again.
    vs commodore
    Oct 2009
    Tamworth NSW
    Id check the wiring going to the SRS module under the drivers seat and also check fuse number 18 under the steering column..If theres a problem in the SRS system and the SRS dashlight is on,then there will be a certain error code logged to show what/where the problem may be.Obviously you need a scantool that will connect to the SRS system to be able to retrieve these error codes.Also some scantools cant acess the SRS system,I know that some snap on scanners will,and obviously the Tech 1 will as well..
    Heres a list of the SRS error codes..
    DTC CODE DESCRIPTION PAGE No.
    13 Driver's Airbag Circuit Short to Earth
    15 Driver's Airbag Circuit Short to Battery
    23 Passenger's Airbag Circuit Short to Earth
    25 Passenger's Airbag Circuit Short to Battery
    31 Driver's Airbag Loop Resistance High
    33 Passenger's Airbag Loop Resistance High
    34 Passenger's Airbag Loop Resistance Low
    43 SRS Warning Lamp Short to Battery
    44 SRS Warning Lamp Circuit Fault
    48 Ignition Input Voltage Low
    49 Ignition Input Voltage High
    53 Configuration Mis-Match
    55 Sensing Diagnostic Module Fault
    66 Airbag Deployment Commanded
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    VS_Pete_1's Avatar
    Dec 2007
    Quote Originally Posted by The1 View Post
    wrong kettle of fish there pete
    OK in what way?
    Please enlighten me.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Confusing ABS with Air Bags......
    .....Iv'e done it.
    VS_Pete_1's Avatar
    Dec 2007
    Sorry hehe I`m a dick.
    I know u`s will beleave me when I say I was up early and had a bad nights sleep.
    That is all.
    Cheers Pete.
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. 95 VR Calais - speedo/ dashboard light problem light problem
    By fseven in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-12-2010, 12:01 PM
  3. VT V6 - airbag light is showing in the cluster? is always on...? problem?
    By CV6Z in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-04-2010, 03:18 PM
  4. Problem with Airbag Light - 98 VT
    By Normy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-01-2007, 08:30 PM
  5. vr airbag light problem
    By crimnl73 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-08-2005, 11:31 AM
