HI
When i lock my ute the hazard lights start flashing and wont turn off, i did a search and couldent find any thin.
Have a look to see if it is earthing out anywhere as this could be a short that is causing it, otherwise check your hazard switch to see if that is the cause
take the fuse out for now...
If its only when you lock, I would say the BCM (Body Control Module) is faulty.
