Results 1 to 8 of 8
Thread: HELP! vs auto, stalled at lights, wouldnt start then started & engine lights on????
    vs wags
    Jan 2009
    Default HELP! vs auto, stalled at lights, wouldnt start then started & engine lights on????
    i was driving down the road tonight, came to an intersection and after about 30 seconds of sitting there my car stalled. (auto ecotec) the electrics still worked though. when trying to start it nothing at all happened. i pushed the car to the side of the road n popped the bonnet and couldnt see anything out of the ordinary. tried to start the car again and it started after about 10 seconds of trying to start and now the check engine light is on... any ideas?
    ...theres also been a very light buzzing sound once i pass about 60kms, it sort of sounds as if somethings rubbing against a tire but theres nothing. not sure but could be related?
    Quote Originally Posted by Burns48_VR View Post
    Hey guys i was painting a set of interceptors and i got some of the silver paint on the wheel, just wondering if anyone knew of a good way to get it off or to cover it up??
    Quote Originally Posted by jamaar4 View Post
    Learn some can control toy
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    sounds like the CAS is on its way out, but i would be checking your error codes first. post them up and we'll go from there.
    vs wags
    Jan 2009
    you need a special computer to read the codes yeah? i think the the CAS has had it anyways, although when it went in my old vs it never affected anything whilst driving, only when you turn it of then try and start it again (when warm)... plus the check engine light never came on last time. come on people need suggestion here!!
    VS V6 Acclaim
    Jul 2008
    No computer needed to check error codes. Just a paperclip.
    Do a search for "vs error codes".
    Check it out and do it, then report back with the numbers.
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Checking your Computer for Faults (VN - VP)
    Just Commodores - For All Your Holden Commodore Needs
    I had no error codes on mine so I just replaced the cas. All good now about 3 years ago common fault.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    vs wags
    Jan 2009
    Yeah I know it's a common fault, I knew it was ####ed anyway cos the other day it wouldn't start when it was warm.. Then worked after about 15 mins. Tested it... Got code 46 whichhas no reference?? Wtf???? I'll test it again n see what happens.
    vs wags
    Jan 2009
    my mistake, got 46, 47 and 12. so 46 is nothing, 12 is normal, and 47.. guess what... crank angle sensor. is it common for the CAS to cause autos to stall tho? my last vs was manual and when it had the ####ed CAS (for about 4 months) it never stalled once... only the starting issue. could it be cos manual or more mechanical based, in comparison to autos? also any ideas for this sort of humming sound im hearing at sort of 60kmh+
    VS_Pete_1's Avatar
    Dec 2007
    Mine stalled when I was going 60k/h but I was lucky it started stright away while moving.
    No codes and yes mine is an auto.
    Sorry no idea about that sound.
  1. Changing VE sv6 lights to HSV lights. any problems with projector lights
    By SV6.VICTORIA in forum VE Holden Commodore (2006 - ?)
    Last Post: 03-06-2011, 01:39 PM
  2. Vt Beebs on start up, Engine Oil Abs lights on unable to retrieve error codes
    By fr1day_vt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-01-2011, 04:16 PM
  3. VT stalled and now wont start
    By Doka in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-12-2010, 03:53 PM
  4. Car stalled now wont start HELP!!
    By TwilightFlame in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-12-2008, 09:25 PM
  5. VX wouldnt start
    By paulc1964au in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-08-2005, 08:06 PM
