took my cluster out to change the lights and they worked foir a day then they started flashing??
then i took them out again and now they wont work at all??
note: its not a fuse
has anyone had this problem and can anyone help?
My VS Statesman 3.8 LTR http://forums.justcommodores.com.au/...an-3-8ltr.html
WTB: UL IRS springs. SSL front springs. VS SENATOR WHEELS, VS VR CAPRICE/STATESMAN LOWER BAR LIPS, Cheers.
bulbs or leds?
if ur using leds theres kits at jaycar or ebay which lower the current/volts to match the leds needs other wise your pumping to much current through them, i had this issue with my led parkers n my dad helped me out knowing more about circuts than most people n i havnt had an issue since.
just bulbs, but all good i fixed them
I hope you didn't turn the ignition on when you had the instruments removed - if you did it will set a fault code and cause the airbag light to stay on.
it was a dirty socket, at the back of my cluster. i just got my air blower and gave it a good blow out and now its fine.
and no my air bag light is not on, i knew about the fault code
