Hey,
I have a VR Calais 1994 and my wipers wont turn off after i use the wipers. If you play with the stalk switching to diffrent speeds it sometimes turns off.
I HAVE replaced the following
#..Wiper stalk
#..Wiper motor
I didnt replace the short length of wiring with a male and female conector that goes between the wiper motor and the wiring coming through the firewall. it has a little black square on it that may be a switch but i dont know. Could this be it?
Sounds like something is shorting it out. Auto elec?
The wiring diagram seems to show that the only other thing connected to the wiper switch is the BCM. Sometimes BCM faults can be fixed by disconnecting the battery - so try this....nothing to lose. Good Luck.
did u find the problem mate?
