Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Thread: Kickdown
    VR
    May 2011
    New Zealand
    Default Kickdown
    I have a '93 VR, is the kickdown cable or electric?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It has the 4L60E so it's all done electric. 4L60 used the kickdown cable. E stands for Electronic.
    VR
    May 2011
    New Zealand
    >_< hoping it wasn't electric.
    I'm having problems with it changing from 2nd to 3rd.
    vs commodore
    Oct 2009
    Tamworth NSW
    It could be the 2-3 shift solenoid playing up.Id check for any error codes to see if theres any logged,these shift solenoids will set a certain error code when they play up or fail..
    Heres a link to a post that shows you how to do this simple error code test..The error code for the 2-3 shift solenoid circuit in in the auto trans is error code 81
    ---Checking error codes VR/VS (Revised)---
    96 S II VS Clubby, 96 VS S II Executive
    Jul 2010
    perth wa
    well my vs v6 is a cable with the 7hdd and 6hdd gearbox, im pretty sure it has an electronic gear change aspect to it aswell.
    Stuntmanmike: At least he didn't advise for me to check the head light fluid and bring it in to tune the radio...
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by Cpt Awesome View Post
    The VR and VS dont have a kickdown cable,its done electronically..
    VR
    May 2011
    New Zealand
    Cable kickdown
    Just a little more tweaking, it'll run smoothly again!
    I ran an error test, lots of flashing in threes, I gave up counting once I got to 30 flashes. Good thing or bad?
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by Lusitano View Post
    Cable kickdown
    If its got a kickdown cable,then the trans is probably out of an earlier model.The VR workshop manual doesnt mention anything at all about a kickdown cable so the VR obviously doesnt use one,unlike the VN and VP manuals which mention the cable and show how to adjust it etc..
    VR Executive 3.8
    May 2011
    is there a possibility that the car is in limp home mode? if so then this will explain it also
    VR
    May 2011
    New Zealand
    Quote Originally Posted by azzaholic View Post
    How will I know if it's in limp home mode?
    VR Executive 3.8
    May 2011
    Does your car take off in 1st? if you have to take off in 2nd or put it in drive and it only takes off in 3rd then will be in Limp Home Mode
    VR
    May 2011
    New Zealand
    It takes off in 1st.
    VR Executive 3.8
    May 2011
    VR
    May 2011
    New Zealand
    VR Executive 3.8
    May 2011
  16. #16
    VR
    May 2011
    New Zealand
    VR Executive 3.8
    May 2011
  18. #18
    vs commodore
    Oct 2009
    Tamworth NSW
    As I said above,if theres a problem with the trans,it should set an error code to help point you to what is wrong..do an error code check..
  19. #19
    VR
    May 2011
    New Zealand
    vs commodore
    Oct 2009
    Tamworth NSW
    I did run an error check, I mentioned that above too...
    Ah,I missed that.If theres nothing wrong,It should just show a continuous code 12 which is one long flash(tens),followed by two short flashes(units).If thers an error code logged,It will show a code 12 to show its the start of the error codes,then after its flashed up any logged error codes,it will flash up code 12 again to show the end of the test..
  21. #21
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    if it has a kickdown cable its had a vn-vp box fitted will be heaps of error codes LOL but none will effect the vn-vp trans operation
  22. #22
    vs commodore
    Oct 2009
    Tamworth NSW
    If it has got a kickdown cable,then its not gonna be a shift solenoid problem as these ones arent electronically shifted..
    Has the car got a kickdown cable or not?
  23. #23
    VR
    May 2011
    New Zealand
    Quote Originally Posted by Brett_jjj View Post
    Yes, my car has a kickdown cable.
  24. #24
    vs commodore
    Oct 2009
    Tamworth NSW
    Well,theres two things,one is what delco posted,the transmission error codes ,if any are set,which there would have to be unless its had a VN/VP ECU installed in it,or if the memcal has been modified,will not effect the transmission operation.And two,the shifting problem will not be shift soleniods as the non electronic versions, which were fitted to the VN/VP and use the kickdown cable, dont have these shift solenids like the electronic versions..Theyd have bands that can be adjusted... not too sure what the problem would be.Maybe it just needs a band adjustment..Has it been serviced at all ?New filter and fluid..You could try that.
  25. #25
    VR
    May 2011
    New Zealand
    How would I know if the bands need adjusting?
    I don't even know how to do that either.
  1. kickdown cable?
    By lufkin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-02-2010, 10:47 PM
  2. vn kickdown cable....
    By vn_v6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-01-2010, 07:29 PM
  3. kickdown cable
    By mundine in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-03-2009, 07:00 PM
  4. Kickdown cable
    By 10000_fists in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-04-2007, 01:45 PM
  5. VP kickdown cable
    By Namheul in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-04-2005, 04:47 PM
