Hey all,
I have a VS an I'm wanting to wire up the foglights.
The foglights are plugged into the loom, I have a relay in the relay socket in the relay/fuse box in the engine bay, however I cant seem to find a plug taped back under the dash for the foglight switch.
Any ideas of what needs to be done?
Mat
Originally Posted by garth
u need to splice in a plug, which from memory is the same plug as the A/C or Hazard plug, so off to the wreckers and cut as much of the a/c / hazard plug as you can get.
If you can get a spot light plug out of a L3 loom... it's pliced in via the dark blue to the head light dark blue wire and the purple red clips into the grey dash plug. Then you need to splice in the orange white, brown white and black wires to the dash loom. Job done![]()
and 3 Dangerous non ABS VN's
You guys are life savers, I will explore this a little more tomorrow,
an hopefully be able to post up an image of the foglights working!
Worst case scenario I'll atleast hopefully have the wiring setup for when I get a plug for the foglight switch.
I have a full SII VS Statesman dash kicking in the backroom of the garage in a safe spot, That I might butcher it's loom.
I'll be going in the VS with a VS SIII statesman Console, Going to use the berlina loom tho, it has dual airbag an that dash supports it ^_^
Mat
There will be a voilet/red wire in a grey multi pin dash loom connector called yb 124 (there are 3 multi pin connectors joined together to the right of the fuses under the swing down panel inside the cabin) that runs from the fog lamp relay base under the bonnet along the main loom through the firewall to it and if you earth this violet/red wire it will energise the fog lamp relay coil and , if everything is plugged in, turn the foglamps on.
and you need to tee off a couple of wires at the headlight switch for earths to feed the switch and orange/white wire for 12v+power for fog lights on indication lamp in the switch and brown/white wires for switch illumination 12v+supply.
Then you could modify the wiring under the bonnet (like everyone does) a bit so you can have the headlights and foglamps on at the same time.
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
I would have thought if the loom is there for the relay and lamps, then the plug would be there for the switch also?
After inspection of my VS SII Statesman dash I have in the garage, On that dash loom the wiring is just taped back, So when I put that dash in, it'll be straight plug in, But currently I want to wire this one up,
It appears that the Foglight button is the same as the demister switch plug,
So I am off to the wreckers to cut out some wiring ^_^
Mat
Just got some plugs from the wreckers for $2 in total
Sent from my iPhone using Tapatalk
And we are done!
I can hear the foglight relay click under the bonnet when I turn it on.
Now I just need to figure out why the foglughts aren't actually lighting up,
Will have to double check the globes as they were pre-fitted when I purchased the car.
Have some pics
I assume these are meant to be connected.
Same thing on both sides.
Back of headlights:
Engine bay side of what the foglight loom is plugged into:
And we are done
A big thanks to
88GreenVN
markovr
ephect
Mat
so are those wires the fog light ones???an how did you plug the in to the lights.
