I replaced my front and rear brakes yesterday,and discovered my brake fluid on vs is a green color..wtf??This is the first time i have done my brakes in this car..Dose anyone know whats going on..maybe needs flushing.
Some brands of Brake fluid is Green
and some are clear, some are blue, and some are red.
lol..what colour do you wan it to be?
Mines blue... and I got a mate and his is purple?
So long as you used BRAKE fluid to the manufactures specifications for your vehicle and not washing detergent you should be OK.
If it's the first time you have done the brakes in this car you should definitely replace the brake fluid. You can then choose your own colour !!! Best to choose a different colour to what you already have as it makes it easier to see when the new fluid has appeared at the caliper you are bleeding.
the break fluid i have bought is an orange colour..it was about that in my vl as well....i just thought it was dirty that all.
ive bought bottle of brake fluid before, same grade, same brand, same purchase, some clear some were blue, just the dye, as long as it's the same DOT number rating then it's fine. DOT4 is what is specific. DOT4 will also absorb moisture so change ideally every 12months.
