Results 1 to 23 of 23
Thread: VS Calais Door Trim Lights
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    Default VS Calais Door Trim Lights
    Hey Guys,
    Just bought some VS Calais leather door trims for my VS Berlina.
    Just wondering how to wire up the lights so they come on when I open the doors.
    Do I have to wire it up to the switch that makes the interior light come on or do I have to add a switch so they don't all come on at the same time? Any help appreciated.
    Thanks in advance.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    VS Berlina/ KJ Verada
    Sep 2006
    I'm actually looking on ebay for those lights to install in my berlina. I would most likely just wire them up to the switch that turns the lights on when u open the door... i'm no auto electrician tho, just a fan of trial and error diy!
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    Quote Originally Posted by -SWE11L- View Post
    Yeah, because they didn't come out in the berlina, I guess theres no wires behind the door trim (except for the electric windows).
    With my dads VR Statesman, they come on seperately depending on which door is open. (Example, R/H/F door opens, R/H/F door trim light comes on (but others stay off)). But in my WH Statesman, when I open any door (or unlock the doors) they all come on at the same time.
    turmoil117's Avatar
    turmoil117 is offline Donating Member
    vn berlina, vr statesman
    Jan 2010
    Westminster
    Quote Originally Posted by superchargedvs6 View Post
    If you wanted this to happen you could run a positive wire to the light then run an earth from each light in each door to it's corresponding door switch. If that makes sense
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    Quote Originally Posted by turmoil117 View Post
    Yeah thats how I want them to work, like on my dads VR Statesman. What you have said does make sense. Only thing is, I have to work out where to get the positive wire from. With the earth wire, I can just put that anywhere on the door.
    turmoil117's Avatar
    Jan 2010
    Westminster
    The positive wire can be from anywhere as long as it's constant 12v it would also pay to fuse it. The earth would have to be spliced into the back of the door switch itself
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    Ok thanks for the advice. Ill give it ago once I pull the old door trims off, before I put the new ones on.
    VY SS
    May 2011
    Auckland
    Do you have electric windows? You can steal power from the feed to the switch. (on rear doors and fronts if the switch isn't on the centre console.)
    A bulb won't draw much current
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    Quote Originally Posted by m1lky View Post
    Yeah it has electric windows, the rear windows have switches in the door trims as well as on the centre console, and the front ones are just on the centre console (no switch in the front door trims).
    VY SS
    May 2011
    Auckland
    Actually that prob won't even work for the rears sorry, the lights would only work with the key on.
    Might have to run new wires to each door. You could loop it off headdeck permanent power wire or just go back to the battery.
    Cracka is offline Banned :P
    Old Sneakers
    Mar 2011
    Croydon
    look under your dash at the fuse panel, you have several constant power feeds that you can neatly and factory looking fit a fuse to. Holden have kindly left you several spares to use for your upgrades. Just need a new fitting, attach your wire to fitting, push fitting in from behind, route wire, push fuse into factory fuse location and WHALLA!
    Hope that helps guys because it will make it a much neater, safer and sexier install.
    Quote Originally Posted by Julie View Post
    Just curious why a fella without kids wants to know what our kids eat... are you that dude in the dodgy free candy van?
    http://forums.justcommodores.com.au/signaturepics/sigpic83720_1.gif
    Sep 2006
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Remember that the door switches pull a wire to ground. The other end of the door switch wire goes to the BCM.
    A direct 12v connection to a door switch will freak out the BCM.
    IIRC the Berlina/Calais has a double contact (single for Commodore/ Acclaim) door switch. One contact for the BCM and the other to run to light in the door trim.
    *Someone with a wiring diagram confirm???*
    VS Series II Calais
    Jun 2009
    Adelaide, SA
    sorry and this may be the stupid thing to say but why not just figure out which wire sends the impulse to turn on the lights; splice it and run it to the positive of your light and then just ground it? that way only the light corresponding to the door would turn on? or have i blatantly missed something?
  15. #15
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    The BCM uses a 5v reference and 'sees' when this is pulled to ground. Even wiring it to the earth side of a globe will still send 12v through the BCM circuit when the switch is held open, resulting in a very dead BCM.
    The 4 doors are wired in two circuits. One circuit for the drivers door (for auto headlamp off etc.) and the remaining doors on the other. Even if you could use the existing door switches, the drivers door would be OK but if any other door was opened, all 3 remaining lamps would turn on.
    This is why double contact switches are used for vehicles with lamps in the door trims.
  16. #16
    turmoil117's Avatar
    Jan 2010
    Westminster
    In that case drill four new holes and fit four extra single contact door switches right above the stock ones
  17. #17
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    I would fit the double contact switches, rather than drilling holes.
  18. #18
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    Today I fitted the dynamat and fitted the new door trims (just on the left side of the car). Both lights are coming on at the same time and once I put the other 2 lights in, they will come on as well. The R/H/R door has double contact switch but the other 3 doors have single. Does anyone know what the difference is? I don't see how me connecting the wires together on the single contact switch is any different to using a double because they are both earthed the same.
  19. #19
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    The double contact switch is just that, double contact.
    It is basically two seperate switches in the one housing. One for the trim light and one for the BCM.
    Did you read post #13 and #15????
  20. #20
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    Ok. The way it is now, (all coming on at the same time), would that affect the bcm or would it be ok. Because I was thinking of just leaving it how it is if it doesn't affect anything.
  21. #21
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Im not clear on exactly how you wired it.
  22. #22
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    They are wired to the switch in the doors. Just finished the wiring now, 3 doors come on at the same time and the drivers door comes on seperately (don't know why).
  23. #23
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    I assume you mean to the original door switches and switching earth.
    As in post #15, the door switches are wired in two separate circuits. The drivers door is separate from the others.
    The other three doors are sharing what is basically one switch as they are wired in parallel.
    Using the existing single contact door switches, it is impossible to have each door light come on individually.
    You do realise that wiring it in this way feeds 12v (from the door lamp) up the 5v line from the BCM?
  1. VT Calais Door trim lights
    By sxc_sound in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-02-2012, 10:44 AM
  2. red lights in statesman door trim.
    By Haydz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-09-2010, 09:44 PM
  3. Calais door-trim
    By joe_rolls_commo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2008, 07:29 PM
  4. removing vn calais door trim
    By Dr.304 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-09-2007, 03:02 PM
  5. WTB: VS Calais series one door trim
    By mwb235 in forum Swap / Wanted to Buy / Trade
    Last Post: 23-05-2005, 05:33 PM
