Results 1 to 3 of 3
Thread: super 6 conversion
    vs commodore
    Jun 2011
    deception bay qld
    Default super 6 conversion
    hey guys new to site i guess this gets asked alot but one more time i got vs sedan manual t5 box i want to convert to super 6 should i swap blocks and balance the man flywheel and stuff of short cut it by decompress plates and use the top end of the l67 block ? and wats involve wit both really thankfully for any advise ive done everything to a como but stroke my na 6 and not ready to part wit the car till ive blown stroked or 8 it and looking at all the options b4 i move on to something else
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Welcome
    Should do a search as its been covered a few times recently. In my opinion you're better off swapping for a complete L67 and getting you manual flywheel mirror balanced to the L67 auto flexplate (they run a different balance factor). Far easier than sourcing all the parts required individually and probably a similar price all up. As you're obviously aware, the L67 runs lower compression than the ecotec, 8.5:1 as compared to 9.8:1 so yes with a top swap you'd need to run thicker MLS headgaskets to reduce the compression or only ever run low/standard boost if you left it at 9.8:1. L67 rods are also heavier construction than the ecotec and a bigger dia gudgeon. L67 pistons are also friction coated on the skirt.
    Also check out L67torque.com plenty of L67 specific knowledge there
    vs commodore
    Jun 2011
    deception bay qld
    cheers dude
  1. whats needed in a v6 to super 6 conversion???
    By Adriianz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-04-2011, 06:52 PM
  2. 22s, super super low in the back super low in the front
    By beau_naulu in forum VE Holden Commodore (2006 - ?)
    Last Post: 16-02-2011, 10:00 PM
  3. super 6 conversion
    By Kernal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-04-2009, 11:18 PM
  4. [VIC] vn vp front super low and rear super low king springs
    By tunsa in forum Parts And Other Items For Sale
    Last Post: 24-02-2009, 09:01 PM
  5. super 6 conversion
    By Conn in forum V6 Development And Modification
    Last Post: 29-06-2008, 07:13 PM
