Results 1 to 13 of 13
Thread: VS IRS ABS // Diff Whine / Diff Service / Replacement
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Question VS IRS ABS // Diff Whine / Diff Service / Replacement
    Hey all,
    I have an incredibly loud diff whine,
    I was wondering would a service fix this?
    An throw in some 80-140 oil ? How much is needed?
    If not, off the top of anyones head, Do you remember the tools needed to remove the diff, As I may need to replace it and/or pick one up from the wreckers.
    All help greatly appreciated.
    Mat
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    VY SS
    May 2011
    Auckland
    A service made my vs diff quieter, still whinned a bit though. It's really easy to change. From memory I bought a 1.5l bottle and had some left over
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    i just did a diff swap in my vs ss, used the best part of 2L to fill the new one. tools needed are just a basic spanner/socket set, and some hex head sockets for the axle bolts (but allen keys would work if u had a breaker bar/hollow pipe to swing off them) the breaker bar could come in handy for the diff mount bolts too
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Is it a constant whine, or is it louder when the diff is under load or when you are losing speed ??? Does the sound change if you put your trans (manual or auto) into neutral ??? Have you checked underneath to see how much play there is in your propeller shaft near the diff end ??
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Quote Originally Posted by BlackVXGTS View Post
    It's definately diff whine, Louder as the diff is under load, deeper noise under loud, higher pitched noise off load.
    Barely any play in the prop shaft, Which makes me thing the bearings are gone.
    I might pick up some 80-140 diff oil an throw that in tomorrow to see how it goes, its cheap anyway.
    Mat
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Depends entirely on what is causing the whine. If it's the gears then there's not much you can do about it without new ones. Often it's the pinion bearing which will need a diff rebuild (may as well do the rest of the bearings at the same time). Any other whining sounds usually require a new girlfriend.
    Lack of oil (or clean oil) may have been the cause but rarely fixes the problem.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    VS l67 statesman
    Dec 2008
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Turns out my current diff is a LSD
    So what fluid would people recommend for it?
    Mat
    VS 5L M5 VS 6L M6
    Apr 2009
    after doing a fair bit of research on the subject i settled on 80-140 nulon synthetic oil, about $30 a litre. the penrite stuff was my first choice but i couldnt find it in the shops
    Avoid cluey police
    VS Berlina/ KJ Verada
    Sep 2006
    Did the Berlina's come with the buyers choice of either IRS or a LSD? If u dont have IRS does that mean u have a LSD?
    How often should diff oil be changed and is it hard to do yourself??
    Sorry for hi-jacking ur thread Mat!
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Quote Originally Posted by -SWE11L- View Post
    Thats ok mate, Change diff oil every 50-75,000 km from memory. SImple to do. It's 1.65litres in an IRS diff.
    Berlinas had the choice of IRS & Live axle. Also options of LSD & Single spinner.
    Mat
    Sep 2006
    cool, might change it. ive done 110000km since i bought it and never changed it! just ticked over 230000. how do u tell what kind of diff u have? So could a berlina have just come with a live axle and single spinner?? someone told me once all the vs berlina's were either live axle with lsd or irs with non lsd... bulls**t??
    vs ute
    Mar 2007
    i use penrite sin 80w/140 in my v8 lsd/ irs diff,very expensive $50 for 2.5 litres i was told by a drag racer its one of the best available. Has an LSD additive already in it.
  1. [General] How fix 1 type of diff whine and to disemble a IRS Diff
    By vsl67 in forum Holden Commodore How-To's
    Last Post: 12-07-2011, 07:54 PM
  2. VT II S: Clutch Master Cylinder replacement... and diff whine
    By jazza15 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 07:53 PM
  3. diff whine
    By Matty o in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-03-2008, 07:13 PM
  4. Diff Whine
    By Trevor 062 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-02-2007, 11:58 AM
