Results 1 to 6 of 6
Thread: vs 5lt temp guage
    vs 5L Berlina
    Jun 2011
    adelaide
    Default vs 5lt temp guage
    hi i just bought a vs 5lt and the previous owner had replaced the thermostat but im wondering if its too cold as the guage only goes just over cold.?
    cheers
    vs ute
    Mar 2007
    A couple of things to consider is one, that the thermostat was put back in and second is the sender unit may be incorrect.
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    My VR temp is stubborn. It takes about 15 minutes of driving before it reads just below halfway on the dash.
    vs 5L Berlina
    Jun 2011
    adelaide
    hmmm im not sure i think i will go to the mechanics and get them to test the temp.
    is there different types of sender units? maybe the wrong 1 is in there?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Inspect the sender unit - if it looks undisturbed it will be the original (they rarely fail). The V8 is a big lump of cast iron that takes a long time to heat up, so maybe run it a bit longer. Also, check if your heater is HOT....if only warm it may indicate the thermostat is buggered.
    vs 5L Berlina
    Jun 2011
    adelaide
    the heater is hot. it warms up pretty quick.
    ive driven the car for 1.5hours strait so i think it is getting to full temp lol ill have a look and see which sender it is tomorrow.
LinkBacks (?)
  1. 05-07-2011, 06:30 AM
  1. vr temp guage
    By vrs11 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-07-2010, 10:04 PM
  2. low temp on guage?
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-06-2006, 04:36 PM
  3. temp guage
    By dig3283 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-04-2006, 02:37 PM
  4. second temp guage
    By chevy_big_block_bro in forum Electrical Wiring / Questions
    Last Post: 10-11-2005, 04:57 PM
  5. temp guage
    By vpdood in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-09-2004, 05:08 PM
