Results 1 to 8 of 8
Thread: Need to help a friend, any thoughts on this issue?
    VX SS
    Jul 2005
    East of Melbourne
    Default Need to help a friend, any thoughts on this issue?
    Got this email from a friend of mine today, I have cut and pasted his email below, any one got any thoughts on this?
    G’day Ron,
    I am stuffed if I know…I am getting the old VR wagon I have at Mt Evelyn going, as we need to get out of the rental in a couple of weeks, and there is a bloody strange water leak.
    It is on the left hand side, the the back of the engine…but…the water is coming out of a hole in the main chassis…if you know what I mean…there is a bit also around the lip of the transmission case…
    I have looked above…and cannot see any wet spots or dripping…it is pretty substantial…and it is water…it has the green coolant in it…and the radiator is going down…my first thought was a welsh plug…but doesn’t appear to be…not ruling it out though….heater hoses go into firewall on right side…buggered if I know…any clues…crawling under car with a crap light doesn’t help.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Inlet manifold gasket?
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Buy a better light?
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    VP Exec
    Jun 2005
    Heater core, leaking out of the A/C drain tube/hole in the floor above the trans.?
    VX SS
    Jul 2005
    East of Melbourne
    Quote Originally Posted by Cheap6 View Post
    That may be a good call, I will pass that one on. Thanks.
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    very unlikely to be welsh plug, it would either have to have been frozen, or corroded to the shithouse.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    Cracka is offline Banned :P
    Old Sneakers
    Mar 2011
    Croydon
    if it is comming out of the chassis it is the heater core or related pipework, simple quick fix is to bypass the heater tap.
    E.G remove the tap join the two pipes into a loop. you will end up needing a new tap then too as they tend to break when you remove them.
    Quote Originally Posted by Julie View Post
    Just curious why a fella without kids wants to know what our kids eat... are you that dude in the dodgy free candy van?
    http://forums.justcommodores.com.au/signaturepics/sigpic83720_1.gif
  1. Who is your real friend?
    By black as in forum Jokes/Humour
    Last Post: 20-04-2009, 11:30 AM
  2. Who's your best friend
    By calais_304 in forum Jokes/Humour
    Last Post: 31-05-2008, 01:16 AM
  3. Mans best friend
    By Dayvo in forum Jokes/Humour
    Last Post: 31-03-2008, 08:15 PM
  4. Missing a friend
    By sganro in forum Jokes/Humour
    Last Post: 16-11-2006, 09:12 PM
  5. help for a friend
    By MikeVXSS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-06-2006, 01:18 PM
