Hi All,
For the past week or so I have had a problem on and off when I start my car. I can hear this abrasive scratchy sound coming from the engine when I start my car. It doesn't happen all the time but the first I did notice I had the air conditioner off and then turned it on and it was fine. This afternoon as I was preparing to leave work the car again made the above sound. This time the air con was on. I turned it off and on about 4 times before the sound was gone. Any idea what maybe causing this sound? It's really not nice on the ears.
Any help would be greatly appreciated!
Id almost put my money on a lose belt if its a v8. Either a lose belt or the fan is hitting the shroud for some reason.. How are you with tools in your hand? And does this only ever happen when the car is cold by any chance?
It's a 3.8L V6 and I am not too bad with tools in my hand, and I have friends who are more technically minded.
Yes, it does only happen when it has been sitting for a period of time, 8 - 10 hours or so but not always.
Just had Racq come over and he said its hard to pin point but thinks its a balance shaft?? Any idea how much that would cost?
had a really bad grinding/scratching sound. Turned out to be a crap water pump bearing/unit and dodgy idler pulley.
97 WRX AWD
Tein Coilovers + EDFC Dampener Control - Whiteline heavy duty Rear sway bar - Whiteline Droplinks front and rear
Turbosmart dual stage boost controller
IHI VF34 Turbo - XForce 3inch TBE - Oversized TMIC - Unichip PiggyBack ECU
PPG Straight cut 1st & 2nd, Slight helical 3rd & 4th and standard fifth - HD Clutch - custom braided clutch line
02 wrx 4pot front calipers - DBA500 two peice slotted rotors - Steel braided Lines
BP98 safe tune @ 171.8awkw
