Results 1 to 8 of 8
Thread: (VR) did error check car wont start
    two-bit's Avatar
    two-bit is offline Hiding between the posts
    vs S pac series II
    Sep 2010
    Altona
    Angry (VR) did error check car wont start
    hey all, did the error check as per the JC guide car threw up
    34 (MAP) - Voltage Too Low
    48 Crankshaft Reference Signal Missing
    49 Cam / Crank Shaft Signal Intermittent.
    removed pin removed fuse to reset fault codes removed key left car go back a bit later car wont start, manged to get it started by putting the foot on the accelerator now its running a like an absolute pig, prior to checking it was running okish, not smooth but it was alright.
    any help would be greatly appreciated, motors got 264xxx on it and its a calais if it helps
    cheers ryan
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Your problems are not related to doing the error check. You cant screw anything up by putting a paper clip in and bridging pins to check for codes, interestingly what fuse did you remove? you just disconnect the battery to reset the codes. Sounds like you could have somehow burnt out the MAP sensor and CAS, if they werent already stuffed. You mentioned it was already running crap. Maybe they just chose now to let go completely and it isn't related.
    Either way, replace them and you should be right, both are very vital sensors, you cant really afford not to.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    two-bit's Avatar
    vs S pac series II
    Sep 2010
    Altona
    i removed the engine fuse as per what the Gregory book said had that next to me for the error codes, yeah ill hitch a lift down to autobarn and try and get the sensors is just a pita they chose to go now after the work if put into this car to get it going right
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Removing the engine fuse is the easiest way to reset the trouble codes, (disconnecting the battery is not necessary although it also works), and is not the reason for any of your problems (and won't have burnt out the MAP sensor and CAS). CAS problems are well-known with older V6 Commodores so should be the first thing you replace.
    vnss
    Jan 2007
    wyndhamvale vic
    Correct me if im wrong but does anyone else reckon this sounds like crank angle sensor???
    vn hsv wagon
    Apr 2011
    Frankston
    Could be fuel pump or low battery,if battery to low womt run every thing,
    Aug 2004
    Quote Originally Posted by vncruzr View Post
    C A S = Crank Angle Sensor
    two-bit's Avatar
    vs S pac series II
    Sep 2010
    Altona
    battery is fine, harmonic balancer was a little worn possibly throwing off the cas went to replace it but had problems getting another one, wasn't the standard vr one had been re coed at some stage, cas is in the mail just waiting on it to arrive to put it all back together, just got to sort out the map sensor keeps reading voltage low on the error test
  1. 'fuel gage error' displayed, ute wont start
    By mickey007 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-10-2010, 05:04 PM
  2. how to check error codes on a wk v8
    By alienn in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-10-2010, 07:55 PM
  3. Wont Start, Error Codes
    By Rolla_Rolla' in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-12-2009, 10:04 AM
  4. VZ Fuel Guage Error - Wont Start - Conclusion
    By bigdaddycool in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-09-2009, 10:15 PM
  5. PLEASE HELP! VR wont start error code 48
    By ecotec_powa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-02-2008, 05:45 PM
