Results 1 to 13 of 13
Thread: Vr Auto
    Vr Station wagon x police
    May 2011
    Toogoom
    Default Vr Auto
    My auto is slipping when its cold, only for a few metres in first then it is fine for rest of the day. not sure if i need to replace box or a service should fix it.
    is it a common fault, what should i do
    rch-13z's Avatar
    rch-13z is offline im rick james..... bitch!
    VT Exec
    Jan 2008
    South-West Sydney
    Did you seriously look where you posted or just closed your eyes & hoped it landed in the correct forum.... This is the ASR-Audio section which is a sponsors section....
    Post moved.
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by Chris .p View Post
    Mate Id try servicing the transmission and see how it goes then.A transmission filter service kit costs around $20-$30,available at most auto places.You also need 5 litres of dexron 111(3) auto trans fluid,also around $20 - $30.You just remove the trans pan and replace the trans filter,refit the trans pan using the new pan gasket that comes with the filter service kit,,then top it up with fluid to the proper level on the trans dipstick,pretty easty really, and way cheaper than paying to get it done,which can cost $100 or more.(Im not sure on this price,it may be a lot more these days)..
    May 2011
    Toogoom
    vs commodore
    Oct 2009
    Tamworth NSW
    Cracka is offline Banned :P
    Old Sneakers
    Mar 2011
    Croydon
    Hmmm the 2-4 band is adjustable by use of different length pins.
    However that wont fix your problem :P do the service but I would say you should look at what else may be causing the issue, kind of hard if you don't know what your doing I guess.
    Quote Originally Posted by Julie View Post
    Just curious why a fella without kids wants to know what our kids eat... are you that dude in the dodgy free candy van?
    http://forums.justcommodores.com.au/signaturepics/sigpic83720_1.gif
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    My 2 bob's worth says to go and spend about $15 on a transmission "stop slip" treatment from SuperCheap or Repco....there are quite a few available and the can make the clutches grip a bit smoother and delay the time you will need a new transmission ($2000+).
    They cannot do any harm and can make quite a difference.
    May 2011
    Toogoom
    Thanks for all the help, time to get oily i suppose. joys of motoring!!!!!!! might be time to look for good replacement, only take about 6 hours to replace it taking my time just hate doing them :}
    May 2011
    Toogoom
    i have a little knowledge, but autos aren't a strong point what else could be causing it ????
    Old Sneakers
    Mar 2011
    Croydon
    slipping can be caused by a plethora of things, untill an auto is stripped down it can be hard to tell exactly where the problem is occuring, or at the very least untill an expert drives the vehicle. I am a little reluctant to start suggesting parts to replace simply because it could all end up being a waste of money, what if the problem in your case is a failing pump, or simply a blocked filter, or an incorrectly installed filter allowing air into the valve body?
    As above the only things you can do yourself are to do a service and to add a bottle of stop slip/auto treatment. When you do the service make sure you replace the bung that the filter goes into.
    If the problem continues after this point just take it to your nearest wrecker that does changeover autos, normally they do them for $300-$400 installed with a 3 month warranty.
    May 2011
    Toogoom
    thanks all getting service kit and filter today will let you know how it goes
    May 2011
    Toogoom
    Service & treatment has helped, still not 100% im gathering its on the way out but im hoping it will last a little longer now.
    Cheers for all the help
    Old Sneakers
    Mar 2011
    Croydon
    Glad to hear you gave it a crack. I would be interested to hear how you go with a changeover box if you decide to go down that route.
  1. VE SV6 200 H0 Motor Auto 2008 Transmission Change of Auto oil
    By markholland in forum VE Holden Commodore (2006 - ?)
    Last Post: 31-01-2011, 05:24 PM
  2. Replies: 7
    Last Post: 21-07-2010, 10:45 PM
  3. difference between standard auto and turbo auto
    By Nackerz in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-11-2009, 08:56 PM
  4. Fuel Mileage Holden VZ Wagon(auto) Vs Subaru 2.5(auto)
    By phantomwalker in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-06-2008, 06:38 PM
