Results 1 to 6 of 6
Thread: Brake pad clunk
    VX SS
    Jun 2005
    Default Brake pad clunk
    Hi everyone,
    Does anyone know what is causing the following problem? I cant remember this happening with the old pads, although the new pads were put in when I bought the car.
    It seems when I brake and come to a near stop, the brake pads make a clunk noise.
    The pads are fitted correctly with the shims, and when I had the wheel off, I can push the brake pad towards the rear of the car a few millimetres. Is sort of sits there with the pressure the caliper and piston is pushing on it, although you can then knock the pad slightly and it springs towards the front of the car slightly.
    So I guess the pad is slightly "loose". Originally I thought it was suspension related although this proves otherwise.
    Any ideas???
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    You might need new clips/springs the tension in them might be too loose and the callipers might be the problem the pistons might be stuffed in them
    VX SS
    Jun 2005
    The brakes were checked out about 6 months ago and new pads with anti rattle shims fitted as well, so I think the tension is ok?
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    When you push the pad back, is it just the pad moving or are you pushing the piston as well? You shouldn't be able to move the piston by hand.
    How does the pedal feel?
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    VX SS
    Jun 2005
    Just the pad, so with the wheel off and the caliper still on, if I put a bit of pressure on the pad, I can move it back slightly.
    The brake pedal feels good and there are no issues with braking
    20Reino00 is offline VS UTE
    Vs commodore ute 2000 seriesIII
    Mar 2010
    most likely your pistins in your calipers are warn but if they have been checked they should of told you or fixed if it was that...
  1. alright so, brake pedal = parkers on front and rear brake light. head lights on and..
    By budgieVH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-09-2011, 08:29 PM
  2. Clunk!!!
    By Stretchomatic in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-08-2006, 07:48 PM
  3. Leaking Master Brake Cylinder Connecting to Brake Booster Advice help please.
    By IceDHB in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2005, 02:32 PM
  4. clunkity clunk clunk
    By webbo1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2005, 12:30 AM
  5. Vb *clunk*
    By psykore in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-10-2003, 08:24 PM
