Results 1 to 8 of 8
Thread: Will a high flow cat make a difference?
    VS Equipe
    Jan 2011
    Adelaide, SA
    Default Will a high flow cat make a difference?
    Hi Guys
    Just had my new exhaust system installed Pacemakers through to a 2.5" single high flow muffler system and it sounds great.
    Just wondering if it would be worth replacing the stock cat converter with something like this
    SS304 2.5" High Flow Metal Cat/Catalytic Converter 100C | eBay
    Would be nice to make the exhaust a little louder than it currently is and would help with flow/power a little?
    Just wondering if I will get any power/sound gains by doing this
    Thanks
    96' VS Equipe (Current Project/Weekender) (CLICK HERE)
    Resident VR/VS Addict
    RIDE:42's Avatar
    RIDE:42 is offline crew chief
    vuss
    May 2009
    If you are going to run a cat put one on thats legal that is a pre cat Cheap way out put one on that is off a manual v8 (auto ones 2.25 m6 2.5)
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    100CPI is illegal due to emissions. 200CPI is legal. Sus out ballistic racing their cats are top notch. 8's and 6's have the same cats. You think Holden would bother spending the money on two different ones (talking VS here)
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    If your cat has never been changed there should be a gain/restore in power as it will be blocked with built up carbon deposits, cats are meant to be replaced at around 50,000Km's supposedly.
    VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
    Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
    VS Wagon
    Apr 2011
    Kent, UK
    My VS 3.8 Ecotec has no cat in it, and it is glorious to drive, but it's an import here so the regulations are a bit more lenient.
    VS Wagon Lead Sled <---- Clicky here
    Current mods: 3" suspension drop, 15" alloys, matt black respray, 4x 12" JBL subs in band pass trunk install, red accenting (wheels, ground effects, headliner, dash), Vauxhall Senator leather front seats, decat & custom exhaust system.
    Quote Originally Posted by Mumboman
    We are not a Ford Forum therefore we have some sort of intelligence.
    VX Berlina - GENIII
    Mar 2010
    Qld, Australia
    I'm not 100% sure of the info for a VS V6; but I can tell you for a LS1 setup which I assume would be the same.
    The stock one has 400 cells per square inch. Both 200 and 100 are illegal. From my research a 100 cpsi will fail an emission test; but generally 200cpsi will often come in close on the limit. Also 100cpsi you will smell fumes from it, and I know a few guys who have swapped them out for 200cpsi.
    On the LS1, a big restriction is not necessary the cat, it is the pipe heading into it. It is only 2.25inch but has a really bad crush bend in front of it; making it as good as a 2inch pipe, the VS may be the same.
    The less CPSI the better the cat will flow. By changing you will get more hp and a louder sound. Don't expect to find a lot of power thou, unless your current cat is blocked up the shit.
    QldKev
    QldKev
    commodore vt executive wagon "98"
    Mar 2011
    rosebud,vic. mornington peninsula
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Only some 200 CPSI cats are legal, not all of them. I do the MagnaFlow steel 200CPSI cat, and it is legal. It is one of the few that come in under the EPA emissions limit.
    Visit my Facebook page
  1. How-To: High flow washable air cleaner make it yourself
    By Frd_thmsn in forum Holden Commodore How-To's
    Last Post: 29-04-2012, 03:20 AM
  2. will cats make a difference?
    By mrvx2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-11-2009, 11:58 AM
  3. Will different shocks make a difference?
    By grimavxs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-09-2009, 06:31 PM
  4. Would this make a difference?
    By Fun_Bucket in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2009, 03:58 PM
  5. Does it really make a difference?
    By Jamie_87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2006, 08:53 PM
