Results 1 to 13 of 13
Thread: What is this??? Climate control bit broken off :S
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Default What is this??? Climate control bit broken off :S
    Hey everyone..... was taking the interior apart today to try and fix this vac leak, found that the vac solenoid box wasn't connected correctly. Anywho among my fiddling I noticed this bit lying around..... I have no idea where it's come from.... looks kinda similar to the exec heater controls with the analog switcher.
    Any idea what this is from? Advice greatly appreciated.
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    VP Exec
    Jun 2005
    Maybe have a look on the LHS of the heater box. There is a motor and position sensor for the flap that controls the hot/cold air mix. That's about the only part that has a gear in it. Or did have .
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    yep thats what it is,replaced mine in my old statesman,turns out that wasnt my problem so that was a good waste of money for me
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    VP Exec
    Jun 2005
    I think that it's held in place by self tapping screws only and has a single electrical plug into it so should be easy to R + R. You may, however, have to remove some of the trim that is under the dash for access.
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by Cheap6 View Post
    Hey man thanks for the reply, I still haven't quite understood exactly where it goes yet?
    I looked today and saw a black cog on the LHS that turns slowly with the heat adjustment.
    But I couldn't see where this white one would go? Also I found this cog on the RHS... but it could have fallen off and moved over there somehow.
    Could you explain a bit more? photos of a working setup would be amazing.
    Cheers, thanks for the replies guys - help much appreciated.
    VP Exec
    Jun 2005
    The motor/sensor is about level with the radio in height but behind the LHS of the fascia. That might help find it.
    It's in a plastic housing and there are about half a dozen of those self-tapping screws around it. The gear would have to have fallen out of that housing.
    Of course it may not be from that motor but I can't think of anything else that has the gears. The vent control actuators are all bell cranks or similar I think.
    VS Berlina/ KJ Verada
    Sep 2006
    Hey buddy, if u can wait a few more days i was gonna take apart my dash to replace my climate control sensor so i can have a look for ya and take some pics, prob wont be till sat or sun tho.
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Cheers guys, I've taken apart my whole dash millions of times but never seen this before! SWE11L would be keen on some pics
    I just put the car back together and everything seems fine o_O but I'd like to know what it is.
    Sep 2006
    Hey bud, just thought I'd let u know I finally got around to opening my dash today and had a look around for that part for u but couldn't find it anywhere! Sorry champ.
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by SWE11L View Post
    Thanks any way man.
    Anyone have any clues???
  1. VR V6 93 Acclaim heater control / climate control switch
    By tom slick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-04-2011, 02:26 AM
  2. [VIC] vr vs climate control heater box and climate control panel.
    By python_hunter1 in forum Parts And Other Items For Sale
    Last Post: 25-03-2011, 08:50 PM
  3. climate control,how does it work need to know for climate control conversion
    By bhopper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-07-2010, 12:49 PM
  4. [VR-VS] How to change Heater Control globes (NON climate control)
    By Fonzie in forum Holden Commodore How-To's
    Last Post: 03-08-2009, 11:28 PM
  5. Climate Control/Standard Heater A/C Control
    By swift85 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-03-2009, 07:44 PM
