Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By Bourbonated
Thread: power aerial / antenna VS
    vs berlina S2
    May 2011
    Cool power aerial / antenna VS
    Hi Guys, I am having trouble finding a 2nd-hand power aerial from wreckers. Any suggestions on where to go (now - that's an offer you can't refuse)..Or should I just bite the bullet and give my hard earned to a Holden Dealer.....but it hurts...
    Thanks in anticipation..
    V6 VR Acclaim
    Jun 2010
    It's going to be hard to come across a second hand one. But any local auto shops should be able to order you an Aerpro automatic antenna. Part number as AP6 or Barcode: 9317114865670. Should set you back around $50-80 depending if your locals charge for freight. I was even nice enough to grab a list of your local shops that stock them .
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You may also consider whether you need a power aerial - a manual one costs under $20 and as you live in the big smoke you really don't need to raise the aerial - manual or power, as there is sufficient signal strength.
    V6 VR Acclaim
    Jun 2010
    Or you could just get a wire coat hanger, bend it into a map of Australia (VERY IMPORTANT! LESSENS SIGNAL STRENGTH BY AT LEAST 3db IF NOT SHAPED THIS WAY) and use that instead :P!
    AP70 is the part code for the manual instead.. In case you were wondering :P
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    I replaced mine with the Aerpro AP6 just goes up and down so the switches don`t work.
    The holden one is semi/auto
    The Aerpro is fully automatic
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    VS Berlina/ KJ Verada
    Sep 2006
    Try ebay, quite a few last time i checked as mine also stopped working. Supercheap auto also does a vn - vs replacement for $30.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Try looking up "wrecking berlina" or somthing like that on ebay. Thats how i did it. Just ask them for what u want. I also didnt bother with that auto aeirial setup, its painful tbh. Got mine setup that Up is up and Down is down, at anytime ignition on or off. Just be carful cause i got shoky'd the first time and done $20, i then bough off someone here and it came bent!.....anothr $20. Finally got one but it was an aeropro one anywayz lol $20 second hand. So allup cost me $60 for a second hand third party aerial. You'll want a right angle phillips head to get ur old one out too. The screw on mine was locktited which made it harder:/
    Reaper
    Dangerous Dave is offline Donating Member
    VS Berlina
    Mar 2009
    is the antenna completely stuffed or just the mast broken ?? Aerpro also do a replacement mast, incase the motor is still okay..
    vs berlina S2
    May 2011
    Thanks for that Bourbonated....great work...Have you tried an aftermarket and how did it perform?
    Tks again
    vs berlina S2
    May 2011
    vs berlina S2
    May 2011
    V6 VR Acclaim
    Jun 2010
    Quote Originally Posted by MikeD01 View Post
    Tks again
    To be perfectly honest, I just used a coat hanger.. I don't really use the radio since my stereo has my iPod hooked up to it. Coat hangers perform fine, just the volume is a little soft.. I would imagine with an actual antenna it would work as any standard one will..
  1. [NSW] SL/E power aerial antenna black mask replacement
    By VR38 in forum Parts And Other Items For Sale
    Last Post: 22-05-2011, 03:37 PM
  2. power Aerial
    By paulbenning in forum Electrical Wiring / Questions
    Last Post: 08-02-2011, 10:11 AM
  3. $$$$ for a power aerial ?
    By Northern_Union in forum Car Audio
    Last Post: 15-09-2007, 12:24 PM
  4. Power Aerial
    By SSMarine in forum VY Holden Commodore (2002 - 2004)
    Last Post: 31-08-2006, 10:38 AM
  5. Disconnecting radio antenna/aerial
    By CLE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-11-2005, 11:19 AM
