Results 1 to 14 of 14
Thread: vr tranny
    vr commodore executitve, manual vn executive
    Mar 2011
    sydney
    Question vr tranny
    hey guys, i checked my auto tranny fluid today, and its goldy/orange just wondering what means.., i know that good tranny fluid is supposed to be cherry red.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Probably just means it's due for a service - it darkens with age - the danger colour is brown indicating the oil has been overheated and/or it is discoloured by burnt clutch facings. You can change the oil and filter yourself for about $50 (filter, gasket and oil) or pay anything from $100 to $200 for a mech to do it. It's probably not urgent unless you've noticed the changes are a bit different.
    Mar 2011
    sydney
    yea i might aswell put it in for a service then that way they can let me know if something is wrong. thanx mate
    VR Executive 93
    Feb 2011
    Queensland
    You would more than likely save yourself a fair bit if you do it yourself its not to difficult
    VS Berlina soon to be 5L
    Aug 2010
    Girrawheen
    just messy haha thats why most people bring it to us its not easy as a engine service
    VR Executive 93
    Feb 2011
    Queensland
    too true I have just finished replacing my box twice over the past 2-3 weeks and yeah can be very messy.
    Cracka is offline Banned :P
    Old Sneakers
    Mar 2011
    Croydon
    JUst put a bung in the pan, its only messy once then.
    Quote Originally Posted by Julie View Post
    Just curious why a fella without kids wants to know what our kids eat... are you that dude in the dodgy free candy van?
    http://forums.justcommodores.com.au/signaturepics/sigpic83720_1.gif
    Aug 2010
    Girrawheen
    whats the point in that to do service properly you need to remove sump and clean properly butting a bung in will any clutch material, metal shavings, in the pan
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The idea of the bung is that you drain the hot oil first, and then remove the pan.....much less messier. It is a bit pointless just draining the oil without renewing the filter etc.
    vs commodore
    Oct 2009
    Tamworth NSW
    The way I service my trans is I just leave the rear trans pan bolts in,I just loosen them off a bit,and then I remove the rest of the pan bolts ,then get someone to help hold the pan up whilst I remove the rear pan bolts I left in,then just lower the pan down keeping it level.Ive found that doing it this way, its easy to remove it without making a mess.I use an engine oil drain pan to catch any fluid..
    Old Sneakers
    Mar 2011
    Croydon
    Quote Originally Posted by Jacko84 View Post
    hrmmm as Hako said it is mainly to avoid spilling any fluid when removing the sump, failing that you can pump it out at the cooling lines but this method has the potential to cause damage if you run dry.
    I have serviced hundreds of 4l60e transmissions, and not just the standard filter and fluid replacement but thanks for the tip.
    Mar 2011
    sydney
    hey guys just an update, i looked at the fluid yesterday and it looks similar to motor oil with a light red tinge wtf is going on?? she is booked in for a tranny service on wednesday
    Old Sneakers
    Mar 2011
    Croydon
    Drive it as little as possible and see what they say when you take it to them. It is not always the case that the whole transmission is fubar, depends on whether they can locate the faulty part and whether or not it is easy to get at.
    Sometimes you can get a long life out of a transmission that has had a mild failure, I.E like a solenoid or accumulator piston failing, IF and only IF it is picked up quickly and faulty part is replaced.
    Without seeing the transmission or driving the car I wont speculate any further.
    Mar 2011
    sydney
    ok she had the service and they reckon nothing is wrong with it :/ and the dodgy assholes told me the oxygen sensor was missing a month ago, now they say its fine, because i asked them to put a new one in think i might change mechanics haha, but she is running ok, just got high revs some times
  1. vl tranny
    By linejockey in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-08-2008, 09:57 AM
  2. vs v6 tranny gone?
    By lumina01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-06-2008, 11:48 PM
  3. Tranny on the way out?
    By VNCalais98K in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-10-2006, 09:55 PM
  4. TRanny oil
    By nmj in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-07-2006, 12:04 AM
