Hi all i have vs s2 5.0l statesman and just fished putting my engine back in after a rebuild with head work, cam and 40th piston 10:1, while taking the car for a drive i noticed the brake was getting hard every noe and then so i went for another short drive and when i went to pull up the thing went as hard as a rock and only just stopped me, its not all the time but every now and than, F&^CKING SCARY, Any idea's what it could be anyone
in a word booster...not connected or not working
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
HI, yeh my booster is hooked up dont look that old to, also had the abs unit unpluged un moved to the side a little no bent lines.
no ABS light on either
Sticky Caliper pistons?
If it's not a Symptom its not relevant, and if its not relevant I don't care!
not sure on that, the car has been sitting for three months, before that not a problem at all. she still pulls up in a staight line
Hard pedal is a booster problem.
May be faulty.
Does your cam have heaps of overlap?
This kills vacuum at idle so the booster will only 'recharge' off throttle.
I still would go with a faulty booster.
Is it like hitting the brake when the car isn't running?
As mentioned above, it would have to be booster.
it has a little overlap.
its like pumping the brake up with the car off but goes down to it normal position.
Booster
is
dodgy.
But it's still hard? Like yu have to put a lot of pressure into it?
Maybe look into the sliders on the calipers?
Take them off and grease them a bit and it should assist in the moving.
Also check that your booster is getting vaccum from the engine.
As said above you may your new engine may not be developing enough vacuum.
You may need to have a vacuum tank fitted if the booster is ok.
HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
ok will go over a few more things
Ok every thing looks ok, im going to put the booster fault out of the problem as it was fine before the rebuilt and cant hear air being pulled in, so im going to put it down to the fact i have not enough vacuum on idle to power the booster.
So what are these vacuum tanks your talking about surfwagon and how do they work mate...
Use a vacuum gauge to test how much vacuum you have. Test it at the end of the line to the booster. It maybe something simple like a blockage.
Vacuum tanks (as used in Phase III GTHOs) are a storage tanks mounted between the manifold and booster. Use a one way valve between the manifold and booster tank. The old vacuum trailer brakes used a decent sized storage tank, maybe you could track down one of those, if you need it?
Rule:
TEST everything before you replace anything.
Ok cool, do you know what the minimum vacuum the booster will safely operates at, i think my tuner said when he had his laptop hooked up to the computer doing a base tune he way saying it should have for vacuum on idle than what it did have, im not sure but when i looked it was around the 65 mark.
Also to my trip computer is skitzing out when i free rev the car it beeps and is saying im getting 99L/100km and on idle im getting 0L/100km what the F*&K
