Results 1 to 9 of 9
Thread: HELP needed - trouble with VR cruise control
    VR - V6 BT1
    Oct 2005
    Wollongong n.s.w
    Default HELP needed - trouble with VR cruise control
    Hey all Just finished fitting cruise control to my VR BT1 ( VR )
    I can not get it to work
    I have just found and read some very interesting threads some other members have put up and from what i can see and read i have done everything right ..
    I Have a VR Acclaim im wrecking . Had the 2 cars side by side . Took everything off the acclaim and just installed it onto my bt1. Pretty easy job..
    Trouble im having is that when i press the switch ( on blinker stalk ) to activate the cruise the green cruise light does not come on on dash. I have checked globes and fuse's and everythings fine .. I have also tried 2 different blinker stalks ..
    Anyone have any idea what could be wrong ???
    Thanks
    VX SS
    Jun 2005
    I think there is also a half size relay that needs to be fitted ( sits above the fuse box)
    VS Spac 5spd and r32 skyline 5spd turbo
    Sep 2010
    Mount Gambier
    my "CRS" light doesnt work unless u give the dash a thump. cruise wont work also if under 40, no speedo, bad contacts on stalk
    VR - V6 BT1
    Oct 2005
    Wollongong n.s.w
    cheers guys... I have checked all relays , seam to all be working well. Have tried 68 - 80Ks on free way and tried cruise but wont go on... Have tried 2 stalks , power going into stalk but no power going out ( guessing thare gotta be one going out to activate the cruise )
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The VR does not have the CC relay like the VS....did you install the second brake switch? - if not then the CRS will not light up.
    VR - V6 BT1
    Oct 2005
    Wollongong n.s.w
    I checked all fuses and relays just to be sure , all sweet.. i took everything from the acclaim and put into my BT1 .. just strange i can not get light to come on
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by MR_RX3 View Post
    Did you install the second brake switch? .....this must be installed.
    Sep 2010
    Mount Gambier
    also i once blew one of my rear parkers and it shorted the brake light. if the brake light is shorted/ on in any way it wont go
    VR - V6 BT1
    Oct 2005
    Wollongong n.s.w
    ill check all the lights today , brake light switch was also installed
  1. VN Climate Control Help needed
    By HeatherC in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-05-2011, 07:34 PM
  2. Man conversion-cruise control, will the auto cruise control work on manual conversion
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2009, 12:25 PM
  3. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
  4. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
