Results 1 to 4 of 4
Thread: Vs hsv senator starting issues.
    96 Vs Senator
    Jun 2011
    bendigo
    Default Vs hsv senator starting issues.
    hey i got a 96 vs senator,
    every now and then it desides it doesnt want to start, so u gotta sit and wait 5 minutes then it starts fine, no problems with running and shit. does this every 2 or 3 weeks. took it to a mechanic and they reckon nothing is wrong with it, say computer is fine and everything, anyone got any idea's? battery is fine and shit.
    vr commodore bt1
    Jun 2011
    It might be your key. If the contacts are bad between the key and the contact ring or if your key is going flat. If you have a second key try that. It is a very common problem
    VS 5 Litre BT1
    Jul 2006
    Yep, what noddycommodore said. I had a similar problem a few years ago...new key and contact ring and all good.
    VR Executive 93
    Feb 2011
    Queensland
    I would suggest doing a Diagnostic check (the how to section should contain this info if you are not already familiar), it may have something to do with the Theft Deterent Signal which started to play up in mine to cause the same kind of problem.
  1. Starting Issues
    By VS commy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2011, 07:13 AM
  2. vs senator aint starting
    By sources in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-12-2010, 10:50 PM
  3. vs v8 215 senator not starting?
    By camaro350 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2010, 03:39 PM
  4. Are there any issues with the 2002 HSV Senator?
    By colesy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-12-2008, 11:46 PM
  5. VS Senator Starting Problems
    By bob556 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-06-2006, 12:34 PM
