Results 1 to 3 of 3
Thread: VS V6 engine misfire or cut out
    VX Executive
    Apr 2011
    Ayr Queensland
    Default VS V6 engine misfire or cut out
    I gave my daughter a VS sedan(her first car) which we had from near new it has sort of a misfire but it’s not if you accelerate normal the engine does it however if you accelerate fairly hard to hard it goes fine . I have changed the spark plug leads and spark plugs. It idles well and when you’re at a constant speed its fine it’s just the acceleration part you could nearly call it jerks. Would low fuel pressure cause this?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I doubt low fuel pressure....do a codes check although it sounds like one of the coils on it's way out. Checking error codes VR/VS (Revised)
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    Definately sounds like one of the coils, at the start of exceleration its sluggish but then it picks up,I have had this same problem a few times,but your better off replacing all three of them if it turns out to be the coils because when one of them goes the others arent far behind.
  1. VN 3.8 Engine Misfire
    By TimmyVn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-02-2010, 09:50 PM
  2. VT engine misfire
    By ulagas in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-01-2010, 02:16 PM
  3. engine misfire after engine bay wash
    By billt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-11-2009, 10:25 AM
  4. engine misfire
    By half in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-11-2007, 02:56 PM
  5. TOP SITE - engine misfire diagnostics
    By Koontz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-11-2005, 10:06 PM
