just wondering if 20w-50 is the right oil to use in my 2000 vs 5 litre?
i have read some forums and done a bit of searching but just wondering what other people on here think? cheers
20w-50 is the oil to use,but if your car has high kms on it then use the 20w-50 heavy duty oil.I use the Repco brand oil its the same stuff but cheaper to buy.
Penrite HPR30. 20w60.
the car has done 145 000 that aint to high i dont think
A better oil than the hpr 30 is the penrite pro 15, you can't buy it in 5 lt bottles just 205 lt drums. But if you go into a workshop that uses penrite oil they can sell it to you, it's a 15w 50. Thats what I use in my 5lt
145000 isnt high so no need for the heavy duty oil and if you can afford the penrite oil then get that
i have given my vs a flogging for the last 40000ks. my engine has done 330000ks and has never missed a beat. i recommend NULON 15w stuff comes in a orange container and is rather expensive. and if you have some spare cash buy some additives. i swear by the stuff were others dont. i believe they work and once again i believe nulon stuff does the job. so does wynns. try some fuel injector cleaner, engine flush (if you do exactly what the bottle says very very small chance of doing damage) oil treatment (my favourte).
i just did my service and went on a 700km trip and only used one tank of fuel. which i believe is very good for a v6 ecotec
Holy crap, 700km on 1 tank.
Find that very hard to believe.
i couldnt believe it either. bp premium. pays for it self ! a well maintained commodore helps as well. 59 litre of that shiz :P
i have top gun leads, new spark plugs, injector cleaner every month. 15w nulon oil with the performance oil treatment, 2.5 exhaust from the cat, removed the "pooper scooper" as i like to call it, air filter changed every 10000, bp ultimate every time hit the open road. set cruise to 100 and she is at about 1800 revs. i reckon you would get similar results.
700 that is pretty good my 5 litre gets about 500 round town but the engine has a few mods that would reduce it
thanks for all the comments to guys
I get 350 around town, if that.
New air filter, fresh oil, clean MAF. Dunno what else to look at.
hey ended up using penrite 20w-60 seems like a pretty good oil thanks for all ya comments to
Good choice. I'm using Penrite HPR15 15w60 but will definitely use the 20w60 from now on in an attempt to eliminate a slight piston slap.
i had the 15w 60 in my ute for 5000 kms when i changed it it was like water was so thin
Anything 15w is like water out of the bottle!!
I have tried a couple of different types in my 5l including magnatec, what i have settled on is penrite 10w 50, good for winter and summer. i don't think you need a 60 weight oil with 145000k.
it says the reccomended is 20w50 and it says on the bottle of the 20 w60 if you use 20 w50 than 20 w60 is fine to use and i think itl help me to cause mine was using a bit of oil
I have just switched my VS over to Castrol EDGE Sport 25W-50
I was using Penrite before but IMO the EDGE is great stuff, think I will stick with it now.
