all right so i need to get my rear suspension fixed up, more than likely doing the whole operation by my self which is no drama BUT what i want to know is, i have a lower trailing arm with a rooted front bush which is what i will be replacing.
Due to the fact that it's been broken for a while and the bush does nothing it's bolt against trailing arm eye, Should i replace the arm as these eyes are prone to warping, and also is there anything else of the control arm and bush side of things that i should be replacing so that i get my suspension back to good working order.
Keep in mind that i dont want to go overboard with the suspension and trying to keep price to a relative low without compromising suspension set-up.
Thanks for any input
This is the stuffed bush as you can see it's pretty far gone.
I think you'll find you can buy the arms new with bushes for a fraction more than the cost of the bushes alone on Ebay.....then you don't have the hassle of pressing the bushes in.
yeah i saw these HOLDEN REAR LOWER CONTROL ARM SUIT VB VC VH VK VL VN VP | eBay
Thanks for the advice hako i recon thats wat ill end up doing
I wouldn't go those ones....here are the same items for less than half the price: COMMODORE REAR LOWER SUSPENSION ARMS ..URETHANE BUSHES | eBay
Cheers hako they look good and great price as well, do u think the rest of the running gear should be fine like upper trailing arms and such?
Yeah the ones hako linked are the goods, have bought a few things from that ebay store. All good stuff
CHECK OUT MY RIDE
http://forums.justcommodores.com.au/member.php?u=62088
I'd check every rubber mount for play - pretty easy with a pry bar or long screwdriver. Except for the panhard rod on which the bushes simply push in, all are cheap to buy complete rather than just the bushes. Upper trailing/control arm will probably be gone.
Cheers hako, your'e a real good help mate, gonna save me some money that i can spend on something cool.
hey theres nothing more I can really add as Hako has been spot on with everything that has been said all I have to add is if you are going to replace one side then it may pay to replace the other side at the same time due to uneven wearing
