Results 1 to 10 of 10
Thread: oil to full
    vs commodore ute
    Jan 2010
    nsw
    Default oil to full
    hi just put new oil in my vs 5 litre put the 5.1 litres that the manual says to put in and it is saying on the dip stick that it is to full its reading about 10 mm above the full mark would anyone know why its saying its to full and is it bad to have it to full?
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Did you start the engine and let the oil fill the oil filter? Or did you not change the oil filter? The recomended amount includes oil filter.
    Not a good idea to have it too overfull, get a spray bottle, like windex, etc, a length of fish tank type clear hose, stick it down your dipstick tube and squirt the excess oil out.
    vs commodore ute
    Jan 2010
    nsw
    yeah started it and ran it for a while my sump has a dint in the bottom of it to would this cause it to read higher
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    You need to check the oil when the car is turned off,pull the dipstick out then clean it,do this a couple of times and then on the 3rd check see where the oil is upto on the dipstick.You should always put in less oil than its recommended and then add more if needed.
    vs commodore ute
    Jan 2010
    nsw
    i let the car sit for a while before i checked the oil cleand the dipstick and got that reading
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by lyleedge0 View Post
    I guess a large dent may make some difference to the reading. Don't forget though that when it's at operating temperature it will read even higher, due to the oil expanding when hot. So 10mm on dipstick when cold may be 15-20mm when hot, which is when they are supposed to be checked.
    So I always under fill mine slightly, then check it when it's hot to get the hot reading.
    Mar 2008
    10mm over the full mark on the dipstick wont do any damage to your motor
    if it was full to the top of the dipstick i would be worried
    as the manual says its 5.1 litres
    i would be surprised if you actually drain the same amount out
    with some of the oil sticking to the inside of the motor
    or some of it breaking down between oil changes
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Ever thought about just draining a bit out? For the time it would take to undo the sump plug, and let a bit out. To the time it's taken to make this thread and then reply to comments the job could be done correctly.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    vs commodore ute
    Jan 2010
    nsw
    yeah i drained some out now its reading on full mark when engine is hot so should be ok now
    vs commodore
    Oct 2009
    Tamworth NSW
    For 20 years or more now Ive been filling my oil so its just slighly over the full line on the dipstick,say 3mm over or thereabouts,Ive never had a problem doing this.Its better to have it slightly overfull than underfull.If an engine is overfilled too much though,the crankshaft can hit the oil in the sump as it spins,this can cause all sorts of problems,the oil that gets splashed around inside the engine splashes up onto the cylinder walls ,way too much for the oil control rings to handle, so it can ends up getting past the rings and burning oil when its running.It can also cause excessive crankcase pressures which can blow engine gaskets and cause oil leaks...But if its only over the full line just a small amount,then it wont hurt anything..
  1. full tank hwy k`s same as full tank of city k`s
    By pillzor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-11-2011, 10:06 PM
  2. VS V8 auto differences? - full circle & not full circle bellhousing
    By cringgle in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2010, 09:33 PM
  3. Full or not
    By fmlycar in forum Just Commodores Polls
    Last Post: 19-10-2007, 06:15 PM
  4. F/s Vs V6 Cai Full Set Up
    By chopsy in forum Parts And Other Items For Sale
    Last Post: 16-06-2006, 08:35 PM
