basically got to change back to original steering wheel for a roadworthy,
non airbag and the horn wont work, works fine with the bosskit, but im confused how to get it to work on the old steeringwheel.
theres only one wire from the horn buttons that connects into the little square, where do i add another wire?
Should be a black/yellow on one side and black on the other...basically the horn button shorts the black/yellow wire to earth......that's how the wiring diagram shows it. If you get stuck, just wire an external horn button up.
on my horn pad from the horn buttons, ive got black and purple wires (2 pairs). so then the 4 of the wires connect in the clip with only one other purple wire, thats in the actualy steering wheel by the tiny square earth, sorry if that sounds stupid, i can get pics to show you and i forgot to say, its a VS FOUR SPOKE
Seems strange that the wiring diagram shows different colours but then strange things do happen. I'd post up the pics as I'm sure someone else will know exactly how they connect....I've never played in that area due to mine having airbags.
