Results 1 to 11 of 11
Thread: Vs Tension Pulley
    commodre vs
    Oct 2009
    Default Vs Tension Pulley
    this is my first post here but i really need some help guys, im unsure if this has been covered already but i tryed looking for a thread and couldnt find it.
    I have a series II vs commodore and the tension pulley has snapped (not just the pulley, but whole part with spring needs to be replaced) and i am just wondering if anyone has any idea of how i can remove this part, cheers.
    Cracka is offline Banned :P
    Old Sneakers
    Mar 2011
    Croydon
    well it basically unbolts,.
    Take the belt off, undo the bolts on the unit (One or two of them hold the alternator on too) hmmm oh and the heater lines once unbolted basically just pull out too, make sure you have some fresh coolant and some silicone at hand :P
    Once you start pulling bits off it will become clearer, oh and the unit is pretty expensive brand new from memory.
    Quote Originally Posted by Julie View Post
    Just curious why a fella without kids wants to know what our kids eat... are you that dude in the dodgy free candy van?
    http://forums.justcommodores.com.au/signaturepics/sigpic83720_1.gif
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    I just replaced one recently and it cost $133 from repco,and to take the belt off you need to loosen the tension first using a spanner on the pulley bolt/nut and then pull the belt off,but make sure you draw on a piece of paper a diagram of the belt on all of the pulleys otherwise you will forget how it goes back on.Then as cracka said you need to take all the bolts off it and you need to take the alternator off as well.You will need to carefully jiggle it off,and the heater hose comes out the side of it,put the new one on and then do everything in reverse that you did in taking it off,hope you can understand all of this cheers,
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    And don't forget that the bolt on the tensioner pulley is left handed.
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    Quote Originally Posted by EDGE3 View Post
    holy shit $133,id be going to the wreckers... i remember doing mine on my old vn a few years ago,wasnt to hard just takes a little while.
    Feb 2011
    NEWCASTLE
    Yeh I know Adds_05,I was in a hurry to fix it,I even had Repco deliver the bloody thing for me due to the bolt actually snapping off the pulley due to it being threaded and whoever the last person was to put a new belt on(not me) decided to use locktite on the pulley bolt,but I think even ebay has them for $90,but the brand I got was the DriveAlign which I think on ebay costs $190+ thats the whole assembly not just the pulley,so I got it way cheaper from Repco anyway.
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    of course,when your desperate,you pay whatever, but $133 is a bit of a joke for something like that...
    Feb 2011
    NEWCASTLE
    Yes I know I nearly passed out when they gave me the invoice as Ive never had to replace one b4 so I didnt realise how much they cost
    Old Sneakers
    Mar 2011
    Croydon
    rolf @ loctite on a system designed to not come undone on its own, thats why the bolt is left handed, Sorry to hear you had to fix some other muppets mistake.
    Feb 2011
    NEWCASTLE
    Yeh thanx Cracka,its lucky that the water pump went for me to realise that the tensioner was about to fall apart,as soon as I started to loosen the tension the bolt just fell out so I was lucky It didnt happen while I was driving it.
    commodre vs
    Oct 2009
    thanks a lot for help guys, im going to go buy the parts today and try figure it out all out, if anyone has pictures would be much appreciated but thanks
  1. Rattle - tension ARM or tension PULLEY ???
    By rocco555 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-06-2009, 11:21 PM
  2. tension pulley VR
    By sutto in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-02-2009, 08:26 AM
  3. tension pulley
    Last Post: 08-02-2009, 10:05 PM
  4. tension pulley replace
    By k191350 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-09-2005, 11:46 AM
