Hey Guys, I have the weirdest question of how to change my steering wheel (with airbag) to another one also with airbag as my one has sharp edges all around the horn pad and also missing pieces from around the wheel itself.
All help will be grateful and also pictures would be awesome
Disconnect battery, turn light switch on (to drain any residual current in the SRS sytem). Remove airbag pad, remove sterring wheel. Replacement is the reverse. Do not reconnect the battery or turn the key on until new airbag is connected.
You will need a T30H torx socket to undo the 4 screws on the airbag,these are the torx sockets with the (H) or hollow tip..
