Results 1 to 7 of 7
Thread: vr heater tap?
    94 vr commodore
    Nov 2010
    sydeny
    Default vr heater tap?
    Hey guys just wondering if anyone knows how to change a heater tap on a 94 vr commodore and what in involves .... Mines leaking coolant everywhere I've had to fill my radiator up the last 4 days straight any help will be greatly appreciated thanks guys
    AussiebluVR
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Very easy - all you really need is a medium sized flat screwdriver and a Phillips head.....on a cold engine just unscrew and remove the hoses taking note of which one goes where, remove the vacuum hose, unbolt or unclip from bracket and replace. You'll probably lose a litre or so of coolant which you'll need to replace. Don't overtighten the hose clamps as this can cause leaks. Replace it soon as they have a habit of 'exploding' and dumping all your coolant.
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    if you havent drained your cooling system in awhile this might be the time to give it a flush lol
    i know when i did mine i got stuck because a few clamps had screws(had a screw driver in my car) and also needed plyers which was unexpected... the whole siuation was unexpected lol.. but yeah you might need plyers aswell
    94 vr commodore
    Nov 2010
    sydeny
    VS Commodore 3.8L
    Feb 2010
    weird, just changed mine literally like a hour ago.
    but yer what hako said, very easy stuff, get ready to give ur engine bay a hose cos it will lose a fair amount of coolant in the process, the actual heater tap also slides off the bracket mounted on the strut tower, so its pretty easy to pull that up and work on it with a little bit more space
    94 vr commodore
    Nov 2010
    sydeny
    VP Exec
    Jun 2005
    And bleed through the bleed screw with a funnel in the radiator and the heater dial in any position off cold. It's been covered a few times as to how.
  1. heater tap or heater core
    By calais24/7 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-06-2011, 09:45 PM
  2. Vk heater
    By benjiaka in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-07-2010, 11:31 AM
  3. what is this? (something to do with heater?)
    By budgieVH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-09-2009, 10:31 PM
  4. vr 5.0L heater
    By GRYNCH in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-04-2006, 08:50 PM
  5. A/con Heater fan help
    By Maxie195 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2006, 08:29 PM
