Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 55
Like Tree5Likes
Thread: VR Calais Ignition Problem !
  1. #26
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    The noise on the video when you have the ignition turned off sounds like a relay to me. There are relays in the fuse box under the driver side dashboard, and also in the engine compartment relay housing on the driver side strut tower. Can you isolate where the noise is coming from and replace that relay? Also I would pull out and re-seat all your fuses and relays (while each fuse is out test their continuity with a multimeter if you have one).
  2. #27
    St3alth187's Avatar
    St3alth187 is offline More time than money
    VR Calais 3.8L Manual
    May 2011
    Nyngan, NSW, Australia
    It was coming from the ABS Relay mate and further up towards the ignition switch.
    Its really got me stumped, as it doesn't throw a code... It'll start up in the morning, but once it warms up she goes rat shit.
    I was looking around the engine bay for the earth point for the block... cant remember seeing one.
    They unlock range on my key is good... so i dont think its the key.
    Any ideas :/
    Cheers,
    Jake.
  3. #28
    aussie4life11's Avatar
    aussie4life11 is offline backyard argument starter
    94 vr 3.8l v6 Auto Series 2 Acclaim
    Oct 2011
    Geraldton, Western Australia
    theres one earth in between the alternator and the aircon compressor. it looks like a bolt with lots of extra thread and a nut on it. the other one is near the power steering pump. and the third one should be attached to the frame next to the relay box and the battery attached to the inside wheel arch
  4. #29
    St3alth187's Avatar
    May 2011
    Could only find the earth at the negative battery terminal. The others i could not see :/
    Doesnt seem right ?
    I found these to be strange too.. My gregories manual wasnt much help.
    I dont know which way they are supposed to go :/ and if the lid is actually correct.
    http://i1070.photobucket.com/albums/...7/IMG_0055.jpg
    Positive Wire going to the main fusible link
    http://i1070.photobucket.com/albums/...7/IMG_0056.jpg
    I dont know why they are so big. I've resized them to 150x100 .. :/
  5. #30
    Oct 2011
    Those are your fusable links. they are essentially fuses but they are able to handle much greater amps and voltage. they are for things like your starter motor and altinator that draw and use high currents. ill take a picture of the 2 earths on my car now. ill put them up in a minute.
  6. #31
    St3alth187's Avatar
    May 2011
    Yeah thanks man. I understand what they do just... in which order and in what amps they are supposed to be. According to the shroud they are wrong?
  7. #32
    Oct 2011
  8. #33
    Oct 2011
    well i think the middle one looks blown, may just be the picture. umm... only way to test is to pull one of them out and try the thing it is ment to corrispond to. if u do one of the end ones, means you could loose one of 2 things in your car. i tried to upload some pics of the engine earth points. i dunno if they worked or not but if not have a look in my albumns to see them. there in the albumn called my poor baby
  9. #34
    Oct 2011
  10. #35
    St3alth187's Avatar
    May 2011
    Does anyone think this could be a problem ? It had tape around it... It just looked bad.
  11. #36
    St3alth187's Avatar
    May 2011
  12. #37
    few commodores
    Feb 2011
    victoria
    usual suspects, start with the basics, relays, are any of the tabs on them looking black/corroded/dirty moved them all around in different spots? tried another bcm as it seems to have alot of electrical related problems and not just 1 thing, fairly random ones?
    tried another key if you have one? does it have central locking, if so does it work all the time or do you have to be close to the car and press the buton many times?
    on the front of the engine to the right of the water pump, under the coil packs, there are 2 black wires with eyelets screwed to the block, they're tight and not moving around?
    the big black earth lead running from the battery to the side of the block to a bolt holding the engine mount, is it still secured well and not lose?
    once again, the small black earth led going from the battery terminal to the car's body? same thing, secure and not moving around?
    do you have a set of jumper leads? when it's being a bitch try using a single lead, place 1 end on the negative battery terminal and the other on say the alternator bracket and see if that makes a difference.
    near the battery are 2 plugs, a grey one and a black one, undo them and make sure they are clean as above....
    don't think the pic is a problem, just looks like someone has spliced into it for something, aslong as it's well insulated it can't hurt.
  13. #38
    vs commodore
    Oct 2009
    Tamworth NSW
    I think that fusible link cover (lid) shown in the above pic is off an earlier model and thats why it shows different amperage fusible links to whats actually installed. It was the later VN's or VP's that changed from using the engine injection and engine computer fusible links to using the single "Engine" fusible link in VP. This was changed again in the VR, the proper VR cover should say (from closest to the engine outwards)
    ABS 60 A
    Fan 40A
    Main 60A
    Headlamps 40A
    Blower 30A
  14. #39
    Oct 2011
  15. #40
    vs commodore
    Oct 2009
    Tamworth NSW
  16. #41
    St3alth187's Avatar
    May 2011
    Went to start the car and forgot the ignition switch was out... now the key is stuck at on ?
    I've just recently replaced the key barrel so it cant be that?
  17. #42
    Oct 2011
  18. #43
    St3alth187's Avatar
    May 2011
    Yeah, gunna have to take the switch out tomorrow... sigh.
    The earth between the coilpacks and water pump seem to be okay.
  19. #44
    Oct 2011
    ok. have you tried a different battery? checked all your relays and fuses are working/ have clean terminals?
  20. #45
    St3alth187's Avatar
    May 2011
    Havent tried a different battery. The relays look all relatively new... Its because its an intermittent problem i cant really test it until it happens.. and it usually happens at the worst time.
    Cheers,
    Jake
  21. #46
    Johnsy's Avatar
    Johnsy is offline ★★★★★
    HSV R8 LS3
    Oct 2005
    C/Town
  22. #47
    St3alth187's Avatar
    May 2011
    Im swapping over the tank and sender with a second hand one from the wreckers.
    I lose power on right hand turns and the fuel gauge is absolutely inaccurate..
    I've read somewhere that these can cause intermittent starting issues such as winding over but not firing.
    The problem being the swirl pot on the inside + return lines.
    And maybe the sender is just rat shit.
    So maybe i can fix three things in one go..
  23. #48
    St3alth187's Avatar
    May 2011
    Quote Originally Posted by Johnsy View Post
    I would try a second batt as well....
    The starter motor winds over and the fuel pump gets power to it .. so it cant be the battery?
    Cheers,
    Jake.
  24. #49
    St3alth187's Avatar
    May 2011
  25. #50
    St3alth187's Avatar
    May 2011
    BCM from the wreckers is on its way. A direct match for my car... Was extremely hard to track down.
    New keypad from holden coded to the BCM.
    All should be happening next week... If that doesnt work; Ill be replacing all the earth leads/battery terminals/ Power leads running from the battery.
  1. vs 5.0 ignition problem??
    By badger__rox in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2010, 09:28 PM
  2. VR ignition problem
    By callum humphrys in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-01-2010, 02:03 PM
  3. Ignition problem help needed, Ignition lead fallen out??
    By boourns in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2008, 05:04 PM
  4. 253 Pre-Ignition Problem
    By Tommi5.0 in forum V8 Development and Modification
    Last Post: 31-05-2008, 09:54 PM
  5. vk ignition problem
    By brettyb2002 in forum Electrical Wiring / Questions
    Last Post: 19-10-2007, 07:25 AM
