i have replaced bcm computer everything and it just wont stop please help
It definitely sounds like a problem with the BCM.Have you checked the BCM wiring.Its about the only other thing,other than the BCM itself,that could be causing all these to play up all at the same time..Was the replacement BCM the same level as your old one,low level, med level or high level etc.
Think back to exactly what work you've done on the car just before this problem appeared - the solution will be there.
