Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Like Tree4Likes
Thread: How do i take out my springs?
    VS dream is offline Lets go cruising!
    VS Executvie SeriesII
    Oct 2010
    Frankston, Victoria
    Default How do i take out my springs?
    Can someone give me a guide on how to get these suckers out? thanks
    Originally Posted by crewsy
    Non turbo, normal POS lancer.. although he has a G-reddy sticker on the back so it must go hell fast
    Cracka is offline Banned :P
    Old Sneakers
    Mar 2011
    Croydon
    front or rear? if rear live axle or IRS?
    we will need a little bit more info to help you buddy.
    Quote Originally Posted by Julie View Post
    Just curious why a fella without kids wants to know what our kids eat... are you that dude in the dodgy free candy van?
    http://forums.justcommodores.com.au/signaturepics/sigpic83720_1.gif
    Drawnnite's Avatar
    Drawnnite is offline Obviously Unsensible
    2000 Vs Ute
    Sep 2010
    just use an angle grinder, make sure to wear safety glasses though.
    but seriously. more info is needed, however...
    this is a basic version of events.
    1. undo wheel nuts
    2. jack car up and put on stands/hoist
    3. take wheels off
    4. put spring clamps onto spring and tighten, make sure its all even
    5. undo main bolts holding the (correct me if im wrong) shockers (the top bolts)
    6. take springs off
    7. and i cannot stress this more do not completely undo one spring clamp all the way. do them evenly so the spring doesnt fly out taking you with it
    do the reverse of this to put new ones in.
    although it may differ depending on the suspension system
    how about we make the pedals out of sticky rubber and the shoes with steel spikes. at least my shins would like that
    Quote Originally Posted by Jonesy484 View Post
    yeah i wondered the same thing when i was 4 when i grabbed the chrome exhaust of my dads rx7
    Quote Originally Posted by DM 55 WA View Post
    did you think it was a milo tin?
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    If your car already has lowered spring and you have a big enough jack they sprigs will fall out on their own, otherwise your best to head down to supercheap and grab a set of spring compressors for about $50. Jack up your car and apply the springs compressors and pull em' out...
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    if your car is already lowered it makes things much easier, i can change the springs in my irs in about 20 minutes. Never done the fronts on any car, ive heard there a bit of a bitch and time consuming
    Old Sneakers
    Mar 2011
    Croydon
    The springs shouldn't just fall out, you need shorter shock absorbers 304runner.
    Again the process between front and rear is very different, and IRS to live axle in the rear differs too, I have only ever needed spring compressors for the front strut assembly, never needed them on the rear for any size spring an any commodore.
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    They fall out in my Ute... Does that mean I need shorter shocks?
    And now i think about it this happens to every one of my mates lowered cars, IFS or Beam rear end.
    calais24/7's Avatar
    Jul 2009
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    That's what cable ties are for....
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    vs commodore ute
    Jan 2010
    nsw
    if your doing the front
    jack the car up undo wheel nuts take off wheel
    behind your brake rotors will be two bolts at the bottom of the strut undo these than the bottom should be loose
    the brake hose is attached to the strut two you have to twist the little pastic thing than it slides out
    also you have a sway bar link attached to the strut undo the nuts off it and pull it out
    now go into your engine bay to the top of the strut and undo all the nuts from that be sure to put somthing under the strut to keep it from falling out
    once you have undone all the nuts the whole strut and spring should come out
    now get your spring compressors and compress the spring until it is loose than get a 10mm spanner and i think a 22 or 24 not to sure onto the top of the strut this is the hard bit getting that undone
    once you have that undone there is one more nut which is pretty easy to get off
    than everything else slides off with it make sure u remember how everything goes back on
    you are most likely going to need two new strut top bearings as they fall apart most of the time when taking out springs
    repeat this for other side
    the back is pretty simple jack car up take off wheel
    undo the bottom nut off your shocks pull the bottom of your shock off
    lower diff as far as it can go without breaking the brake hose
    than put spring compressors on your spring and compress them until you can get your spring out
    repeat for other side
    i may have forgot some things two as it has been a while since i did mine but this just gives you a rough idea of what to do
    hope it helps
    Old Sneakers
    Mar 2011
    Croydon
    your meant to run shorter rear shockers with shorter springs especially if the springs can be taken out by hand with the rear of the car jacked up, whether 99% of people do it or not is not what I said, it's not worth arguing over, back to the OP
    Have you done it yet and how did you go?
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    The amount of travel a jack can make far exceeds anything the car will experience in it's life time so it's not a concern. I had the same thing but it was a good 30 centimetres from top of tire to guard before it was lose enough to fall out on it's own.
    vs commodore ute
    Jan 2010
    nsw
    if you have standard shocks and ssl springs than you may have problems if you take on steep driveways at an angle
    Old Sneakers
    Mar 2011
    Croydon
    Quote Originally Posted by vs-v8-ute View Post
    Like I said, your meant to run shorter shocks. I have super lows in my car with shorter rear shock absorbers, I think they cost $60 brand new from Repco for the rears, the fronts are more expensive but since that spring is captive you have more of a choice as to whether you do it or not, I did but it didn't seem to make a difference so I wont be forking out for shorter fronts again.
    Still keen to hear if the OP managed to get the job done
  15. #15
    Oct 2010
    Frankston, Victoria
    im about to start it now, just had to get rid of the hangover haha thanks for all the help guys, its vs exec II and im just taking out the rears (its all stock atm)
  16. #16
    Oct 2010
    Frankston, Victoria
    also what do rear live axle and IRS mean?
  17. #17
    vs commodore ute
    Jan 2010
    nsw
    IRS is independent rear suspension which means the axles move independantly of the diff and solid axle means it all moves horizontaly together
  18. #18
    Oct 2010
    Frankston, Victoria
    do you know what a vs exec II have?
  19. #19
    VS Executive S2
    Aug 2010
    melb
  20. #20
    VS Berlina soon to be 5L
    Aug 2010
    Girrawheen
    umm not to sure about that my berlina is irs i thought executive might have been live axle, to the op jack car up take wheels off while on stands and take a pic and post it well let u know
  21. #21
    vs commodore ute
    Jan 2010
    nsw
  22. #22
    vs commodore ute
    Jan 2010
    nsw
  23. #23
    Old Sneakers
    Mar 2011
    Croydon
    simple way to tell is if the diff is up against and attached to the floor of the car it is an IRS setup.
  24. #24
    calais24/7's Avatar
    Jul 2009
    Quote Originally Posted by VS dream View Post
    IRS and solid axle have differant springs. How can you be just about to start when you don't know what your car has?
  25. #25
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    the springs are different for irs and solid
    so i hope u got the right springs?
    also i thought all vs's had irs lol
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
  1. [NSW] WTB VU front v8 struts/springs and rear springs standard height
    By dreammist in forum Swap / Wanted to Buy / Trade
    Last Post: 23-12-2010, 11:55 AM
  2. King Springs low front springs, are they lower then FE2?... oh and the rears..
    By mike49 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2010, 07:32 PM
  3. Lowering car, change just springs or springs + shocks
    By wildeagle44 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-01-2010, 06:38 PM
  4. [QLD] swap Solid axle springs for IRS springs for the rear - Goodna
    By Gus The Snail in forum Swap / Wanted to Buy / Trade
    Last Post: 10-04-2009, 07:59 PM
  5. FS: Whole Suspension Setup (Springs , Shocks, Struts) King Springs
    By ssmate in forum Parts And Other Items For Sale
    Last Post: 01-11-2007, 06:24 PM
