Hi,
Does anyone know where the vac solenoid that controls the heater tap in a vr v8 calais is?
Someone has removed the tap and vac line on mine.
I've seen heaps of info on the standard AC system but not on much about thr climate control version.
Any diagrams or pics would be very apreciated.
Thanks
The heater tap is the same for climate control or standard A/C and the vacuum solenoid is on the tap. Also, if the previous owner removed the tap to by-pass the heater then it may be due to a leaking heater core.
MY RIDE
vacuum solenoid for heater tap is with the rest of them in a block underneath the storage tray below the stereo.
Thanks wamboin,
any idea where the vac line goes through the firewall?
where the heater lines go through.
theres two of them - one from the engine to the solenoids, and then one back to the heater tap
sorry, accentstencil. I flicked straight to the bottom of the page, missed your post.
Thanks for your reply too.
i meant the solenoid that sends the vacuume to the heater tap actuator.
The core is fine, its just been running full flow.
