Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By Brett_jjj
Thread: WTB Small Relay/Fuse box, with only main fuse.
    ShawtyNate's Avatar
    ShawtyNate is offline Kicker
    '94 Holden VR Acclaim
    Jun 2011
    Moree NSW
    Default WTB Small Relay/Fuse box, with only main fuse.
    I need the relay box from under the hood, its the one that says ABS, FAN, MAIN, HD LAMP or something and BLOWER.
    Does anyone have a spare one, all i need is the box with the MAIN fuse in it.
    Thanks
    Nate
    Cracka is offline Banned :P
    Old Sneakers
    Mar 2011
    Croydon
    take a pair of side cutters and head to the wreckers, find a base model poverty pack that no one will miss and cut it off. Then to avoid being charged for the whole loom but to ensure your not a thief grab a handfull of random rubbish from the ground and pay $5.00 - $10.00 for that
    The only reason I say this, is because i'm fairly sure its part of the main loom and cannot simply be unplugged or pulled off easily.
    What happened to yours? fire?
    Quote Originally Posted by Julie View Post
    Just curious why a fella without kids wants to know what our kids eat... are you that dude in the dodgy free candy van?
    http://forums.justcommodores.com.au/signaturepics/sigpic83720_1.gif
    ShawtyNate's Avatar
    Jun 2011
    Moree NSW
    ShawtyNate's Avatar
    Jun 2011
    Moree NSW
    nah one of my mates were helping me see why my car wasnt starting, we pulled out all but the main fuses and replaced them and my mate dropped the hammer and crumled it.
    VP MANUAL S/C 3.8 UTE
    Nov 2006
    Country Vic
    For the amount of effort in finding another small fuse box it will be heaps easier to go out and just buy another fuse to replace the 1 that has been broken
    Quote Originally Posted by HoZy View Post
    Please insert your keys into your rectum an sell the car for scrap...
    Regards
    Mathew
    Ek wagon 0-60mph 6.19 20/4/07 G-Tech so there is no cheating 1/8th mile @ mph Unknown , estimated 1/4 mile Unknown
    ShawtyNate's Avatar
    Jun 2011
    Moree NSW
    turmoil117's Avatar
    turmoil117 is offline Donating Member
    vn berlina, vr statesman
    Jan 2010
    Westminster
    Isn't it just bolted On? I mean the whole point of a fuse is to
    Protect the wiring, if the fuse blows and you have to replace the whole
    Box that would seem a little pointless
    vs commodore
    Oct 2009
    Tamworth NSW
    The main 60 amp fusible link has a small bolt holding it in,whereas the others either side of it will just pull straight out..This small bolt is located just down under the fusible link holder,theres a small plastic door/flap that opens outwards and theres the bolt up inside there.You can follow the main positive wire where it goes from the positive battery terminal to the fusible links etc as it also goes straight to this same bolt, it joins up to the main 60A fusible link in there behind the plastic flap.
    VS V6 Acclaim
    Jul 2008
    There's actually two 10mm bolts holding the spades on either side of the box.
    A small flathead will lift the flaps to remove the bolts and slide the fuse out.
    ShawtyNate's Avatar
    Jun 2011
    Moree NSW
    vs commodore
    Oct 2009
    Tamworth NSW
    At the point of the screwdriver in the pic is the bolt that holds the main yellow 60 amp fusible link in its holder.Just undo this bolt and the main 60 amp fusible link can be pulled out and replaced..Sorry the pic isnt a bit clearer..
    Attached Thumbnails Attached Thumbnails WTB Small Relay/Fuse box, with only main fuse.-100_0737.jpg
    ShawtyNate's Avatar
    Jun 2011
    Moree NSW
    vs commodore
    Oct 2009
    Tamworth NSW
    You have to buy this specific fusible link,they are not like the common type of fuses that most cars use.You will probably have to see holden to get one.....
    EDIT:Heres a link to a couple at supercheap auto..Im not sure if these will fit as the one you need has the bolt through it holding it in the holder..But it gives you an idea of what to look for..
    The ebay one has the holes through its legs for the bolt,so Id say its the one you need..
    ---http://www.supercheapauto.com.au/onl...18#Description---
    ---http://www.supercheapauto.com.au/onl...19#Description---
    ---http://www.ebay.com.au/itm/Fusible-F...item2a10a4e056---
    ShawtyNate's Avatar
    Jun 2011
    Moree NSW
  15. #15
    VS V6 Acclaim
    Jul 2008
    Male - Products - Narva
    You need the 60A version which is part# 53160BL (1).
    Note the bolt holes in both blades.
    Changed one only a week ago. Any auto shop stocking narva should have it for $5-7
  1. VZ fuse and relay box
    By 2005vzute in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 23-06-2010, 12:21 AM
  2. Main fuse blowing
    By gendi in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-03-2009, 05:40 PM
  3. main fuse keeps blowing up
    By vnv690 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-07-2006, 11:11 PM
  4. why my VX has 1998-1999 relay and fuse box ??...
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-04-2006, 02:45 PM
  5. Blown the main fuse :(
    By sobvngrpa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-10-2005, 09:50 PM
